Receiver Set Up: Small or Large
bembol
bembol Posts: 18
I just picked up my new Polk Audio CSi3 center channel, is it considered a Small or Large speaker? I need to set it on my receiver.
Is there a difference?
My current set up is...
RT25 Bookshelf Fronts with
PSW120 8" Powered Sub
My room in the basement is small so no place for Rears...
Thanks!
Post edited by bembol on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2005
    it depends on the rest of your system and what you have in terms of a sub and main.
    I'd set it up both ways and see which you prefer...
  • bembol
    bembol Posts: 18
    edited April 2005
    I just edited my post...
    What are the benefits? I've always had the fronts/center on Small.
  • AsSiMiLaTeD
    edited April 2005
    setting to small will probably blend with your mains better and will present your amp with an easier load to push (because it's not driving those low ohm levels at lower frequencies)
    Setting to large may give you a more full sound fcrom the center, better for male vocals and the such.
    They are both viable options, and neither will damage the speaker or amp, so just try both and see which you like...
  • Willow
    Willow Posts: 11,311
    edited April 2005
    FWIW, my ci3 is set to small along with all my other speakers, as mentioned I let the amp on my sub do the work for the lows.
    VR3 Posts: 29,633
    edited April 2005
    The RT25i are small speakers, and should be handled as such...
    However, with that said, I have run ALL of the Polks that passed through my abode on large for hours on in and they handle it flawlessly. It may add more PUNCH to your music. Try it.
  • Willow
    edited April 2005
    I've often thought about doing that, I just wonder how much info under say 50-60 hz will play on the center or mains during a movie or tv or music
  • bembol
    bembol Posts: 18
    edited April 2005
    I left it on small.
    I'm not sure if I'm seeing things but I saw some distortion/coloring on top of my HDTV. I took off the speaker and it went away...
  • landry_p2000
    landry_p2000 Posts: 1,313
    edited April 2005
    I set all speakers on small except for my RTi10 towers. I thought that the CSi3 was shielded. Is your HDTV tube or projection?
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Willow
    edited April 2005
    it is shielded it may be his mains that are not shielded
  • landry_p2000
    edited April 2005
    He said his fronts are RT25s. I am not sure, but those should be shielded also. I wonder what caused that distortion?
  • landry_p2000
    edited April 2005
    Yep they are also shielded. I just looked them up on the Polk website. I still wonder how that could happen?
