Tube Preamp Choices ?
tapeshc
Help me here, dont know what to do.
I need money(buying house) so my current Pre-amp has to go. Its Pass Labs X2.5.
I need a replacement but Tube one not SS. Cheap with remote.
So I found this Dared SL-2000A.
Pros:
It has remote
Has good build quality
Looks are good too J.
Cons:
Two Inputs
Then I saw Dodd Audios ELP. Talked to Gary, he agreed that for additional $100.00 I can get two more inputs. But I cant get remote.
Price wise both will cost same, so no problem there.
Which one would you choose and how will you resolve the problem of More Inputs or Remote.
Ofcourse if you can suggest any other tube preamp that will be nice too.
Pros:
It has remote
Cons:
Two Inputs
Tapesh
Tapesh
You don't need a remote.
Turn it on, Ronco the ****, sit down and get your listen on.
Cheers,
The remote is for the volume only and is handy.
http://clubpolk.polkaudio.com/forum/search.php?s=&action=showresults&searchid=310873&sortby=lastpost&sortorder=descending
