Good 8" sub for SQ under $150
kenstewart
Hey fellas, keep me in my price range now. I'm expecting my sub w/enclosure this weekend from UPS (custom box for my Explorer Sport Trac). The sub is an 8" RF 3408, 200 watt RMS. Now, I want clean bass not boomy stuff so guess that means I'm an SQ guy. So, any of you know if this sub is SQ or SPL type and also please give me your thoughts on what decent SQ subs are in my price range. Thanks ...
Eclipse CD8445 HU
Image Dynamics CXS54 Chameleons component setup
Two 8" Image Dynamics ID8D2v.3 subs
MTX MXA6001 amp for subs
MTX MXA3002 2-channel amp for comps
Accumat and Peel-n-Seal
Stinger and Knukoncpetz wiring
Post edited by kenstewart on
Im not real familiar with RF subs but they are pretty solid however they tend to be more of the SPL persuasion.
A great 8" SQ sub is our own Polk MM2084. Handles 200 RMs and sounds great.
There is also the JL 8W3, the Diamond Audio CM38D4 (but I dont think they make em anymore), MTX has a couple as well.
8's are hard to find. Which sucks cause Ive always liked em.polkaudio sound quality competitor since 2005
Mac, do you think for a cabin the size of my Sport Trac that a single 8" should do fine? Need good clean bass to help complement my DB570s. Would like a 10", but then I need to get a different box. Here's a different question ... would having that 8" behind my 40% rear passenger seat and then a 10" under the 60% part of my rear passenger seat mess up the bass sound? Just curious if this will totally screw it up or be any benefit.Eclipse CD8445 HU
Stinger and Knukoncpetz wiring -
Its usually not a good idea to mix subs. If you want a 10, get one.
I like an 8 cause Im not really much of a bass head. I like it as much as the next guy but I listen primarily to heavy metal and a lot of bass sounds like crap.
Ive always used 8's and have always had good luck with them. I am however thinking about going with a 10 this time around just for something new.
Personally I think an 8 would be fine for your car but you wouldnt be going wrong with a 10 either.polkaudio sound quality competitor since 2005
Ok, guess the only real deciding factor left is listening to it. Thanks for the help Mac
Eclipse CD8445 HU
yeah, space and your dB requirements will decide... but it is generally difficult to seamlessly integrate multiple subs of different sizes, it tends to sound odd.It's not good, very fundamentally simply not good. - geolemon
Ok, rec'd sub/enclosure today and hooked it up. Not sure if I've got everything set correctly but man what a difference already!!! Had my son check it out because I was fiddling with the gain and other amp settings so much I was starting to forget what it sounded like before ... he noticed an immediate difference and amazed how good it sounds. Mac, you're right this single 8" fits the bill ... unless I start shopping again later and see another new toy
Eclipse CD8445 HU
the methodical way to fiddle with the gain...It's not good, very fundamentally simply not good. - geolemon
I printed that out and used it Neo (saw your previous post). Just not sure if I have it as good as it can be since this is my first time tuning a sub, but heck it still sounds good. Today my second amp comes in for my DB570s and I'll hook that up this weekend.Eclipse CD8445 HU
Neo, the Web-Pimp!
hell yeah!Originally posted by MacLeod
Neo, the Web-Pimp!
I think maybe you should sell that box, and go with a MM2104 sub for the explorer. I have a MM2104 in my civic, and i have an amp pushing 200w rms to it. and i think its great for me..being a guy who is not a bass junkie..
but also it depends on what kind of music u listen to..if u into hip hop and jazz..a bigger sub would probably suit you. also you have alot of room in a explorer..so maybe a 10"inch will do better then an 8"'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
(the wife's new ride)
..new project..wife comes first before s2k -
Thanks guys for all the help! I installed everything today; ran short on time so I don't have everything fine tuned but it sounds sweet
No major probs and everything seems to be working great.
The 8" seems to be working out awesome so far, but thanks for the recommendation JDM ... maybe later I'll look into it since I'm happy with what I've got now
Eclipse CD8445 HU
sweet, glad it's workin out for ya!It's not good, very fundamentally simply not good. - geolemon
Mike over at Soundsplinter (www.soundsplinter.com) is coming out with an 8" sub later this week. It is an RL-i8, and is a sub that is geared towards SQ. Look on the left side of the webpage for a picture. I have an RL-10 and I am very happy with not only its SQ, but also with its output capability. I paid $159 for it (they go for $164 now), so I think that the 8" will go for less than $150.
Here is another link where there are a few pictures of the sub.
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=2348
Here is a link for the T/S parameters. I believe Mike said that it has an Xmax of 17.8mm or so.
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=2348&st=90Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
the basket almost looks video-shielded... strange... sounds like a nice piece of equipment, though (breaks the 100 dB barrier in preliminary modelling, not bad at all)...It's not good, very fundamentally simply not good. - geolemon
I dunno. Looks kind of funky to me.
Id like to hear one tho.polkaudio sound quality competitor since 2005
I've heard very good things about soundsplinter. As well as the other company as well that makes the Magnum...sound something I think...I've heard one, and they are very clean.
-Austinhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
Man, these little, independant subwoofer companies are springing up all over the place.
Used to be only a handfull of companies made subs. Now theyre everywhere.
Thats cool tho. Competition is always good for the consumer!polkaudio sound quality competitor since 2005
Yeah, but makes it hard for us non-physics or EE types to determine what's best bang for the buck
Guess I'll have to just stick around here and keep on learning from y'all ... Eclipse CD8445 HU
That's the best way. Just read reviews from guys that are EE and physics types. Get on a forum that deals a lot with the specific brand in question. You'll quickly get a feeling of how good the brand is by the type of reviews it gets. If nothing else, I'd get Ascendant Audio or Polk from their EXCELLENT customer service. Ascendant recently lowered their prices for the Atlas line, and gave every customer that bought one before the drop a refund for the difference! Ever heard of a company doing that?Originally posted by kenstewart
Guess I'll have to just stick around here and keep on learning from y'all ... http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
that's just friggin ridiculous!It's not good, very fundamentally simply not good. - geolemon
Personally I like sticking with the big boys. I trust their quality more.
Not saying the indys are crapfully made, just that I trust a JL Audio or Diamond Audio more than a RE or the like.polkaudio sound quality competitor since 2005
I use to say the same thing till I found out that some of the companies that sell long excursion drivers do not actually make them. They have companies like TC Sounds (www.tcsounds.com) make them to their specifications. These build houses as they are called are the OEM manufacturers to big name companies. So I kind of just went to the source(through a small company
). My subwoofer is actually a TC Sounds TC+2 driver. You could buy these drivers direct from them (they call them their Standard Products). The only thing is that you need to buy at leat 50 of them. I do not need that many so I went through the smaller company. Another company that also sells their stuff is Oaudio (www.oaudio.com), but they only sell the 12's at the moment.
Over at Maxima.org in the audio forums there is a guy that goes by RobertJ. He was the one that told me about TC Sounds as well as other build houses. This guy really knows his audio, and is very helpful. He also hangs out in several of the home audio forums. Once I get done moving I will unpack my old computer and get some links for you guys. Just waiting (praying) for escrow to close so I can get in my house and unpack.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
This has one of the links I mentioned earlier (I dug around Maxima.org a little). Take a look at the bottom of the page for Robert's post, it is #30. Just to show where I got it from.
http://forums.maxima.org/showthread.php?t=353781
This is the link where the TC2+ was tested. Take a look around his site.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
many people like to stick with the big companies, but there is usually a price premium, and customer service issues
I run the forums at SoundSolutionsAudio.com and TeamSSAudio.com, the home of Stereo Integrity and SoundSplinter,online forums,
both companies make excellent products, and have top notch customer service, I have gotten to know both of the companies staff very well,
on top of that I just recently finished a demo on the new Stereo Integrity MAG D2 prototype, you can see the pictures and short review in the Stereo Integrity forum, I can tell you this, it is one of the top SQL subs I have ever listened to, and for the price is makes other BIG companies seem like a waste of money..
I have a SoundSplinter RL-p 12 D2 on the way, it is the big brother to the RL-i 8 that is posted above, it uses the TC9 motor, and I am very excited to hear it, in a recent review it beat out the much more expensive RE **** in a fair head to head competition,
all I am saying that the little companies need some consideration, both SoundSPlinter and Stereo Integrity have excellent quality and performance to meet or beat the big companies for less money and a lot less hype -
id like to see the tests against the ****, its not exactly the best subwoofer out there for sound quality
here is the link from the test >>> http://www.soundsolutionsaudio.com/forum/index.php?showtopic=2234
Mac,
I've been looking at this MM2084 for some time now. Crutchfield has it for $80. Have you heard it as one sub or multiple? Really debating on whether or not to go ahead and buy it, just uneasy 'cuz I haven't heard it in person.Eclipse CD8445 HU
Also, I'll need a spacer to put the MM2084 in my enclosure. The recommended mounting depth for my enclosure is 3 13/16" ... according to Crutchfield, the MM2084 w/boot is 4.182 and w/out boot is 3.94.
Any help on making one of these? I'm sure it's not hard, but I know you guys will give me good ideas w/out me having to resort to trial and error.Eclipse CD8445 HU
