Amp?
Systems
I just bought a rockford fosgate amp model number 700s and I was wondering if that is enough or too little to push two MOMO 12's? Thank you
Testing
Testing
Testing
Testing
Testing
according to crutchfield you should put at least 75% of the rms power into the subs
if that amp is rated at 700--350 per channel--then it should do fine
and usually rockford fosgate amp push about 100 more watts than theyre rated
is it bd technology??
if it is i think it should do fine
