amplifiers
sansui80
I need some input on a choice of two amps.
1st Luxman M-117 200wpc 500.00 used 8/10 .
2nd Aragon MKII 2004 100wpc @8ohm and 200wpc @4ohm
400.00 7/10
Both fully functional want to drive a pair of SDA2 speakers
any other suggestions for a amp under 500.00 would be appreciated.
thanks,
Ben:)
400.00 7/10
thanks,
Ben:)
Post edited by sansui80 on
I'm not sure, but this amp might work pretty good for you here on the forum: ATITschüss
Zach -
ATI amps are non-common ground. Don't try it unless you have an AI-1 interconnect or at all on some of the older SDA's.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I'm glad you caught that. I didn't even think about the common ground requirement.Tschüss
Zach -
Are all ATI amps non common ground?I tried the 300 watt stereo amp on my SRS 1.2tls' and it worked fine.Ive emailed ATI to be 100% certain because youve got me worried!If it was a non common ground amp what would normally happen?
PS the sda was defininatley working -
ATI got back to me and you are right they are all non common ground.
Of those two I would likely vote for the Aragon. The early Lux was some fairly nice stuff; but I was less impressed with the Lux that came out in the mid to late 80’s.
Aragon made a pretty nice amp for the money. You might also hunt for Adcom; either a GFA 545 or a 555 are about as good an amp you can find for typically under $ 400 used. -
The Luxman M-117 is a great amp for SDAs. I've used one for 2 years driving 1Cs. It's on the FM now, but bluecomet has dibs. If he backs out, send me a PM.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
