Pre-amps
Spawndn72
I am looking for a cheap(er) pre-amp to get me by until I can afford a tube pre-amp. I am looking to find something under $100 shipped. I know that is asking alot, but if I have to spend much more than that, then I think I would be better off just waiting unitl I can afford that Dodd that Russ has hooked us up with. Looking on ebay I see a Nad 1020 going for $50 with about 9 hrs left, I see a HK Citation 11 going for $50 with a little over a day left and an Adcom GFP-555 going for $79 with 5 hrs left. Which one of those would be a better hold-me-over pre-amp?
I guess the next question is, anyone got a cheap(er) pre-amp for sale?
Thanks,
Todd
Thanks,
Todd
Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Pioneer DV-578A Multi-format
Polk SDA-2 Mains
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Polk SDA-2 Mains
Post edited by Spawndn72 on
Most of those auctions will most likely go up inprice before auctions end. you need to look up ended auctions to get a true reference of price..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Yep, I figure they will all go up, but you never know when you will get lucky.Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Polk SDA-2 Mains -
Be patient. Save your money for a tube pre-amp. Used ones come available all the time at $250 and up.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
