Speaker Size in HT
Earthy
Earthy Posts: 488
edited April 2005 in Speakers
On the hunt for speakers for my new home theater. It's 14 x 15. I'm curious if there is any advantage to having all larger speakers in a 7.1 setup as opposed to large fronts, and smaller surrounds.
What do you all think?
Earthy
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Post edited by Earthy on
  • beardog03
    beardog03 Posts: 5,550
    edited April 2005
    IMO, the rears don`t need to be large...
    they are for ambient sound
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2005
    For mains:
    If your speakers are going to be used on the small setting with a sub for HT, then the only advantage is the "cool factor" of towers.
    If you plan on using them for 2 channel music also, then the towers make more sense. They may sound better without requiring a sub.
    For surrounds:
    I wouldn't waste real estate (floor space) on big speakers. The surrounds like it better above ear level anyway. Go smaller here.
    It really is still your choice, there is no right or wrong, only choices.
    Your room may dictate your needs.
  • Earthy
    Earthy Posts: 488
    edited April 2005
    I had the luxury of desiging this space and put the entry between the left front and left surround speaker. I have the floor space, or wall space or whatever. This is MY space (wahoo!). I do plan to listen to music in there some, but will have a primarily listening setup in the living room.
    I have some LS 70's I plan to use for mains, and had the option to get another pair at a reasonable cost. I have also looked a getting 4 B&W 602's to go with the LS 70's but wonder if I will be wanting to upgrade them too soon if the B&W's sound much better.
    Thanks for the input!
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • jmierzur
    jmierzur Posts: 489
    edited April 2005
    My 15 x 13 room. I decided to use all small speakers.
  • Early B.
    Early B. Posts: 7,900
    edited April 2005
    For a room your size, I'd go 5.1 with bookshelf/surround speakers in the rear mounted on the side walls, esp. if your primary seating position is close to the back wall. In a larger room floorstanders all the way around would be awesome.
    "God grooves with tubes."
  • Earthy
    Earthy Posts: 488
    edited April 2005
    jmierzur, thanks for the link. Looks like I need to consider looking into tube traps also.
    Early, the primary seating will be about 3 or 4 feet from the back wall. I will probably go with the smaller speakers on stands. That's one of the reasons I was thinking of towers all around.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2005
    Think wall mounted sats for the back. I would go something like 80-90% of your speaker budget on the front three and the rest for the other two/four. The fronts are what you really hear in the movie's and also, 2-channel will benifit as well. That's how I would start on a tight budget.
    If budget isn't that much of an issue, I'd try and go with 7 of the same speaker.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Sami
    Sami Posts: 4,634
    edited April 2005
    I don't know, that room is rather small for 7. Same speaker, yes, but 5 of them.
  • jdhdiggs
    edited April 2005
    Good point, that is a small room
  • Earthy
    Earthy Posts: 488
    edited April 2005
    It seems pretty big to me considering we have been living in a 800 sq ft home for the past 6 years.;)
    I do have another room that's much bigger at the other end of the house, but it's right over the bedooms. Besides it's our hobby room.
    I only plan to have spase seating, with one recliner in the sweet spot, or possibly a love seat/recliner? I figure our seating at 10' from a 50ish" screen, leaves us with room behind for the rear speakers. I just need to nail down my speaker choices, so I can move on to the rest of the electronics and video stuff.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • Sami
    Sami Posts: 4,634
    edited April 2005
    Room size is ok, it's just not that big for a 7.1 setup so 5.1 is probably a better option.
    I have my HT with over 100" screen on 13x11 room with a 5 speaker setup and a big SVS cylinder in the closet. It's a good HT room for 2-3 people, all that I really need. It would be nice if it was a little longer, 16x11 or so, but 13x11 works.
