digital coax cable vs. rca cable
vicentre
vicentre Posts: 23
edited March 2002 in Technical/Setup
I have a gold-plated RCA cable running from the digital out of my cable box to the coaxial digital in of my Harman Kardon AVR-320. Should i be using a digital coaxial cable? Does it make that big of a difference?
Home Theater Man Cave
Display-Samsung PN60E550 | Receiver-Onkyo TX-NR809 | Sources-OPPO BDP-103, PS3, Apple TV | Speakers-PolkAudio; mains-RTiA7, center-CSiA6, surrounds-RTi70, back surrounds-RTi38 | Sub-SVS PB-1000 | Sennheiser HD-650 headphones | Schiit Audio Vahalla Headphone Amp | Pro-Ject Debut Carbon Turntable | Musical Fidelity V-LPS Mk II Phono Amp with upgraded power supply | Monster MP HTS 1600 power center
Post edited by vicentre on
  • eeagle
    eeagle Posts: 226
    edited March 2002
    It depends. A digital coax requires a 75 ohm impedance (RG-59) cable. RG-59 is not that expensive. For instance Target sells a 6ft RG-59 (75 ohm) coax/digital cable for $4.95. Works beautiful, every bit as good as the expensive Monster brand in my opinion. Your cable may have its impedance printed on the insulation, if it is RG-59 or equivalent you are in great shape.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • CHRIS
    CHRIS Posts: 454
    edited March 2002
    Digital needs RG-6. Yes a digital cable will make a big difference. Its sheilded so your othe cables won't pick up the distortion for one. Go to C.C. get one try it see if YOU can teel the difference. If you can't take it back. RCA cables come in many types, digital is different then reg. Try a search and do some reading it will be to your bennefit. :)
    Chris :)
  • lax01
    lax01 Posts: 496
    edited March 2002
    I have heard that any RCA cable will work. You should test them both out to see which one you like best. I personally bought a digital coax cable at Rat Shack for $14 and it works great.
