hafler p225 and Carver 1.5t?
doggie750
Need the forum 2 cents here please..........I've done my research and have heard that Carver 1.5t is good. What about Hafler p225?
Scope:
Use x Carver 1.5t to juice my fronts $500/ pair for the amp
Use Hafler as mono to juice my center $100
Scope:
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
I know the M-1.5t well... and like it. Look for one with a serial number >10,000 as it was the last and best version. $500 is pretty high for a 1.5... more like $350 would be right.
Don't know the Hafler 225, but do know the DH-220. The vintage 220 is a great little amp. If the 225 is close performance-wise, $100 would be a steal.
Not sure about the combination across the front stage... might work.More later,
Tour...
Vox Copuli
thanks for the reply...I knew about the serial # has to be > 10000, my question now is should i buy if the serial is the earlier model and not > 10000. The carver is $275 each, $500 a pair.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
< 10,000 would be fine. The over 10k ones are just sweeter sounding... a little more refined.
At $500 a pair you'd easily get your money back out of them reselling. So there's no downside I can see to trying them.
You certainly don't need a pair to bi-amp your 70's, but WTH...More later,
Tour...
Vox Copuli
Thanks again....since I have two pair of tower speakers......was gonna try them in series for my front........so I need amp to drive them.
What do you think is better ADCOM GFA555 vs Carver 1.5t?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Can't really comment on the 555, but want to say I've read here that the 555 is not the Adcom to own...
Do a search on "*555*" and you'll turn up some discussions on it vs. other Adcoms.More later,
Tour...
Vox Copuli
Thanks.....
I got my CARVER1.5t........but I haven't got the chance to tweak them yet........I will this week and I'll post my updates.......Have your heard of SRS KLAYMAN Speakers (Planar)? It's not a polk brand but it suppose to be a highend type speakers? I've done my research but so far no help online. Also, you mention that hafler might not work with Carver, what about B&K?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Never heard of Klayman... You might ask in a new thread in the "speaker" section...
So what are the serial numbers of your 1.5t's?
On the Hafler, you may have understood me, but just to be sure...
What I was questioning was whether the Hafler would tonally work with the Carver. Same would stand true for the B&K... maybe moreso as they are pretty sweet sounding amps... Also can be differences in relative gain, etc... Then again, depending on your speakers, you might not notice a difference.
I lean towards the same amp manf. for HT. A Carver you might consider bridging for a center would be the M-200t (350 W bridged). Decent ones go in the $150 to $160 range on ebay.
What is your front stage speaker line-up?More later,
Tour...
Vox Copuli
Cool........is this the same with PARASOUND HCA-1000A with the Carver. This parasound is about $295 online used. Is it worth getting it? The objective is to use it as mono 400w for my center.
Frontstage:
With Carver 1.5t
2 Rti 70 // with 2 Rti100, may separate low end for separate bass since my receiver has 2 sub outs. Polk doesn't recommend it this way. What do you suggest.
With Parasound HCA1000a
CSi300 bi wired
Would this be okay?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Actually your CSi300 would be bi-amped.
I've probably got you overly concerned about amp differences here. Differences exist, but they aren't that great.
Parasound has numerous followers 'round here. It's be a good choice.More later,
Tour...
Vox Copuli
