Pontiac Sunfire
Airplay355
Airplay355 Posts: 4,298
edited April 2005 in Car Audio & Electronics
How do i remove the big stock HU in a pontiac sunfire?
Post edited by Airplay355 on
  • AustinKP
    AustinKP Posts: 861
    edited April 2005
    I'd try finding a pontiac forum. They'd probably have much more info on that for you.
    -Austin
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2005
    Figure out how the trim panel comes off from around it. Then its usually a matter of removing 4 screws and out it comes.
  • swerve
    swerve Posts: 1,862
    edited April 2005
    I know this is dumb but try www.bonnevilleclub.com
    they may not like you for asking there though....
    but they all know about pontiacs.
    just a try wouldn't hurt.
    cats.vans.bag...
  • Joelsbass
    Joelsbass Posts: 637
    edited April 2005
    if you've already removed the trim pannels there should be 4 screws around the HU, these will probably require either a #7 or #10 socket if memory serves me... if the trim pannel is still on it will most likely simply pop off with sufficent force, If i remember correctly most years of sunfire's didn't have screws holding down the panneling... if it's an older model though it is possible in which case take care in removing the pannel to avoid breaking a bracket...
    If you could post a pic of the car's dash (namely the area around the HU) i could easily give you more descriptive directions.
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2005
    Don't tell us you've given up on the HU.......what's goin' on?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
