Crossover??
Pinktulip7
Pinktulip7 Posts: 249
For my HT 7.1 following setup I have made :
1.Set all Speakers to 80 hz
2.Set Center and side Surround speakers to small from Receiver.
3.set Subwoofer to 60 hz
What else I should do to get better bass on ht?I am replacing my
subwoofer soon,thinking about SVS PCI ULTRA!!Also is there any conflict on crossover?How can I calibrate my speaker's?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
  • malikarshad
    malikarshad Posts: 527
    edited April 2005
    Get a RadioShack SPL meter and AVIA Disc to calibrate your system.
    To my understanding if you are setting Xover to 80Hz in the receiver there is no need to set the Xover on your sub. If there is a switch on the sub to disable the Xover then disable it otherwise set it to 80Hz
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • Pinktulip7
    edited April 2005
    My Sub Xover set to 60 hz!!
  • Willow
    Willow Posts: 11,332
    edited April 2005
    if you get a new sub you could set your mains to small
    let the amp on the sub take care of driving the low notes
    they should have a medium setting;)
  • Pinktulip7
    edited April 2005
    I don't want to set my Front L/R to small!!!
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2005
    If I am reading you correctly, the sub X-over is the only one set stragely. Depending on the model of what you are using for the processor, you ought to set the sub X-over as high as possible to keep you from doubling up on the X-over.
    When you set the sub X-over, was it in the processor or on the sub itself?
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Pinktulip7
    edited April 2005
    All of my speaker's are set to 80 hz and small except the front speaker's,Sub Xover is set to 80 hz which I can change it to 60 hz or 100 hz!!!
  • jdhdiggs
    edited April 2005
    Go to 100Hz. Since you ar feeding the sub from a low pass filter from the other channels already, you don't want a second x-over at the same spot. This can cause a dip in your frequency response around the X-over location.
    What exactly are you trying to solve though? What type of reciever are you using?
    With the 12's, I would set your X-over on speakers @ 60 and your sub at 100Hz and see how that works for you.
