mixing rti with lsi series
vikings22
vikings22 Posts: 5
edited April 2005 in Speakers
would mixing the rti with the lsi series be consider two different speaker types.should you always try and stay with a series?
tv.-sony trinitron wega 34hs510 rec.-h.k.-avr320 pan.-dvdcv51 mains-polk-rt800i center-polk-cs400i rears-yamaha-ns-a835 subwoofer-velodyne-ct-150 amp-adcom-gfa7700 amp-x2-outlaw 200 m-block [shipped]
Post edited by vikings22 on
    VR3 Posts: 29,440
    edited April 2005
    You might get away with RTi surrounds in a LSi setup, or LSi surrounds in a RTi setup - but otherwise... it would be like mixing coke with cereal.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2005
    I have RTI100s as my surrounds in my system with my LSI 15s (and now) LSI9 as a center. They work well. It's not a perfect match but it is pretty decent considering they are different speakers. Eventually I will get all LSI.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • lomic
    lomic Posts: 407
    edited April 2005
    I had RTi6's for surrounds with the front stage being LSi's - after switching the back to LSi's the difference was very noticable. If you listen to 5.1 music, don't even try mixing the RTi and LSi, the result is terrible as the back speakers stand out like a sore thumb. If it's just movies you can get away with it, but a complete LSi setup still sounds more consistant making surround effects less obvious.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • Whadyasay
    Whadyasay Posts: 300
    edited April 2005
    Me too...RTi25's as surrounds with my LSi Front three...works fine. If I really had to compare, I'd say the RT's are a bit brighter than the LSi's, but not so much so that it's bothersome, at least for surround application.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • vikings22
    vikings22 Posts: 5
    edited April 2005
    thanks to all who replied. hey sid how are those def. techs treating you? listened to the bp7002s monday, started saving my money tuesday.:) love the bass. aggresive in your face speaker with endless power. 300 watt 12 inch subwoofers built-in.handels up to 300 watts...lots of sound. can you be evicted form a neigberhood?:p
  • timothyj
    timothyj Posts: 129
    edited April 2005
    FYI Dr. Spec knows his stuff and uses a cs400i with lsi7's for the front stage. I am now using a phantom center but did use a cs245i and thought it blended just fine for movies - sacds revealed its less subtle musical side but it was very listenable.
    I still use rt25i's for rears and since mine are placed near side wall corners I actually prefer them! The brighter tweeter helps with clarity and they are also less "boomy" than lsi7's would be placed in a corner.
    Tim
    LSI7 x 3 (fronts)
    rt25i x 2 (surrounds)
    SVS PB-10 NSD
    Harmon Kardon 235 pre/pro
    NAD amps
    Xbox 360
    Pioneer DV-578A (DVD, SACD, DVD-A)
