odyssey audio
W WALDECKER
W WALDECKER Posts: 900
edited April 2005 in Electronics
does anyone use odyssey amplifiers or preamps with thier polks i am considering replacing my paradigm reference studio 100v3 speakers with sda 1 a speakers i am currently running odyssey khartago monoblocks with an odyssey tempest preamp and a symphonic line vibrato cdp. does anyone think there would be good synergy?
Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
Post edited by W WALDECKER on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2005
    You'll be fine. Their are a couple people that run Odyssey gear here...and they haven't complained to my knowledge.
  • ninerbj
    ninerbj Posts: 870
    edited April 2005
    Although I do not personally own an Odyssey amp, I can tell you that they are on my short list of must own!
    I have talked to several people who own these amps...many run some pretty heavy loads too. All in all, I hear nothing but positive reviews. GO FOR IT!
    "she had the body of Venus, with arms."
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2005
    Someone more knowledgeable will chime in, but I think you need a common ground amp to power those SDAs...
    that may rule out those monoblock amps...
  • Early B.
    Early B. Posts: 7,900
    edited April 2005
    I have an Odyssey Stratos amp that powers the fronts on my HT system. It's quite clearly the best SS amp I've owned.
    "God grooves with tubes."
  • dorokusai
    edited April 2005
    Early has good ears, so the opinion is definetly solid.
