Check out the nakedness...
My panels have faded on my Lsi15's and polk was to the rescue. Read this thread for details...
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=22370
Amazingly, I just now got to taking the old panels off. They came off pretty easy. They were just held on by this double-back tape-like product that came off if you stretched it. You kind of pull it towards yourself, and up. Kind of makes me thing of the 3M product that you stick on the wall to hang stuff on but you pull this piece of tape and the hook comes right off.
Now that I have the panels off today, I'll be applying the new panels tomorrow. But, these speakers look damn sexy now with their panels off! Slender, shiny, piano-black all around. See for yourself. It'll be hard to cover them back up
Enjoy!
Enjoy!
Post edited by jrlouie on
I might be inclined to run them naked and save the new panels until you are ready to resell.
They do look great in the piano black!
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
very sexy..!!
makes me want to sell all my RTxxi speaks and get a pair..!!
Do all the LSi`s come apart like that ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Yeah, I believe they all come apart like that. Other than the LsiC obviously which has no panels
looks great! did you notice any tonal changes? or is it no difference? Thanks for posting, the double tape that you took off, is it available at your local hardware store?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Those Lsis must put out quite alot of bass. They have blown the stucco clean off your wall there!!:DHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
polkatese,
My AVR that I use as a pre-pro, is currently in the shop. So I can't listen to them yet. Since it's in the shop, I thought this would be a good time to do the panel work. I'm not sure about the double-back tape. The new panels have the double-back tape pre-installed. All I have to do is pull off the backing, push the panels on, and I'm done.
Dennis,
) I wish that was the case! Yeah, the walls in this place are bizarre. When they refinished the building, they decided to knock some stucco off, and leave some on and try to give it a historical/artsy look -
I wonder if the panel is more of a cosmetic and balancing feature, rather than anything else. Start visualizing the possibilities...I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
how did you pry the wood piece off ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Well, when polk originally sent me the panels they supplied a "polk tool". It was a white, plastic wedge that looked like a door-stop with a sharp point. Unfortunately, I couldn't change out the panels at that time so I had to return the "polk tool".
But, I found a plastic drywall/plaster knife that I used. I hammered it in first between the panel and main cabinet on the back. But it didn't have the angle the "polk tool" did so after getting the the plastic knife started, I then used a screwdriver utilizing the plastic knife as protection against the piano-black finish. Since I'm getting rid of the panels, I didn't care about the screw driver on the panel. Then just pulled the panels off.
Clear as mud? -
ok...no..!
J/K...:DCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
OOOHHH very nice. I would agree, just use the front panel & leave the sides naked!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I like it better with panels on....it breaks up the monotony. With out the panels, it looks too much like a regular speaker....we all know that they are not...;)System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
BLAST YOU, jrlouie ...!!
Now you`ve got me lookin at LSi15`s and 25`s....!!!
Just when you think your out....they pull you back in..!!
:rolleyes:Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Hey I always wanted to see an all gloss LSi tower or bookshelf. They look a little plain like that. If Polk were to put one in production, they'd need to add some curves or something. I just got a new pair of LSi15's myself, and I'll be sticking with the beautiful cherry finish.
:rolleyes:
lmao. holy **** those speakers look awesome. If you have a traditional den with alot of wood furniture- I like the cherry wood panels on. If you've got a contemporary - style pad- i think the speakers would fit in much better with the panels off or black coverings.
awesome. -
I have ebony wood on my 25s, I like the wood and I love the sound!SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
Wow! I really like the looks of those with no side panels. So much so that if I still had the 15's I would be taking the panels off tonight!
Now i'm re-thinking getting phuz's cherry Lsi-15s. I was worried that the cherry would look like crap in my place, but black would match perfectly. Not sure, I think they are second generation and may pose a problem if they're glued, not taped.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Add me to the "looks cool w/out the panels" crowd. Very elegant.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Now... I want you take take a picture with one thumb print in the middle of all the gloss...Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Nice, I like the lookDenon 3803
Denon CD
old Sony Receiver 110W/ch
LSI25 two rights looking to swap for one left (what can I say it was a good deal on two rights)
CS101 center looking for LSiC
KEF KIT200 and IQ3
Cervin Vega AT-12 and LS-12
JBL TLX181
white van Dynalab speakers -
WOW!:eek: That is amazing! I would leave them naked.
