conflicting crossover settings
klove2
klove2 Posts: 38
Does anybody have some good advice as to set up your base management when your sub and your reciever wont allow you to disable the cut of frequency. I heard that if you turn the cutoff all the way up on the sub this might help minamize the effect .
GEAR
R30S FRONT
R15 SURROUNDS
CS1 CENTER
YAMAHA 5740-RECIEVER
SONY SA-WM500 150 WATT SUB
JVC XV-N410B DVD PLAYER
PIONEER PD-F606 25 DISC CD PLAYER
TOSHIBA 43A61 51" TELEVISION
Post edited by klove2 on
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2005
    Page 26 of your manual has the basic setup information you need.
    http://www.yamaha.com/yec/customer/manuals/PDFs/HTR_5750_5740.PDF
    Setting the sub to "Yes" allows you to select the crossover point (pg.50) between 40 and 200hz.
  • John K.
    John K. Posts: 822
    edited April 2005
    KL, as Frank pointed out, your 5740 has a wide selection of crossover frequencies. With your speakers the most commonly suggested 80Hz should work well. When the sub has a switch or separate input to bypass its internal crossover, it should be used to prevent a conflict with the crossover which the receiver is doing; if, as with the SA-WM500, it doesn't have such a bypass, the next best thing is to turn the subwoofer crossover control all the way up so as to get it as far out of the way as possible. Your SA-WM500 has settings above 150Hz, which may not be strictly accurate, but would result in little or no conflict with an 80Hz crossover in the 5740.
