shopping for music speakers
khanhhuynh4u
khanhhuynh4u Posts: 40
edited April 2005 in Speakers
hey guy im look for new speaker just for musics so could you guy give me a list of some good musical speaker i should look at
some from 200-350 price range and some from 350-500 and some from 500-700
what im looking for are clarity, quality sound, good vocal sounds, mostly im going to listen to classical and piano, and some vocal such as norah jones, josh groban, etc... im not looking for the really expensive high end but ones that are best for that price range....
also if you have any recommendation on receivers and cd player please give your opinion...what im using now is onkyo 8211 receiver and polk RTi4 but im not fully happy yet so im looking for a better system....thanks in advance
Post edited by khanhhuynh4u on
  • malikarshad
    malikarshad Posts: 527
    edited March 2005
    There is a general opinion here that Polk LSi is very musical.
    Look at LSi7 and LSi9 with a sub is a killer combo or go Polk vintage SDA's
    Denon DVD-2900 is a very good all around player. U can easily get it from $400-$550.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • lomic
    lomic Posts: 407
    edited March 2005
    If you really want all the things you listed, you'll need at least the LSi7. Along with that you'd unfortunately also need a decent amplifier cause I don't think that 50wx2 Onkyo will cut it, unless you're ok with keeping the volume pretty low.
    Overall cost for this is probably looking at the $800 range, but I don't think you'll really be happy with anything less.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • 2+2
    2+2 Posts: 546
    edited April 2005
    Ditto the two advice above re LSi....I listen to alot of classical and LSis floor me with a good recording....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2005
    If you're not stuck on just polk, MMG's at $550 shipped to your door are about as good as I've heard for that type of music, assuming you have very good amplification of course.
    The LSi's are better all around if you want to listen to rock and the like or don't have room.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • khanhhuynh4u
    edited April 2005
    any others recommendation? like from NHT, B&W, Epos, Paradigm, PSB???
    how about cd players what name should i look for?
    VR3 Posts: 29,440
    edited April 2005
    CDP -
    Cambridge Audio
    AMC
    NAD
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2005
    The Paradigm Studio 40's used are in your $500-$700 range. To sound best though they also would require better amplification. They would fit your description though.
  • gregure
    gregure Posts: 871
    edited April 2005
    To achieve the kind of sound you're going for with that type of music, you will need excellent speakers and good amplification.
    Personally, I think you should keep saving to get something you're really happy w/ that you can sit and listen to with no regrets, rather than buy speakers now, and amps later, and not be satisfied for a long while. The system you have is decent enough that you should be able to live w/ it a bit longer. A couple of suggestions for systems below:
    Mains:
    1. Lsi 7's ($700/pr)
    2. Lsi 9's ($900/pr)
    3. Martin Logan Montage's ($1500/pr)
    4. Vienna Acoustics Mozart's ($2500/pr)
    Preamp: B&K PT5
    Amp: B&K 125.2 or 200.2
    Sub (Optional): Martin Logan Grotto, SVS PB 12 Ultra (when if finally comes out) or an HSU
    These systems would cost you somewhere around $2500 to $6000 depending on your choices. I know it's obviously higher than your current budget, but I believe a system such as listed above would give you no regrets whatsoever, and excellent sound quality.
    Realistically, the music you mentioned needs a higher priced speaker to sound good, because in my opinion, metal dome tweeters just cannot do this kind of music justice. My ears have grown very tired of metal domes, and ring radiator, soft dome or thin film are the only way to go these days, but you have to pay for it. Hope it gives you an idea of what a really nice system would cost.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • dragon1952
    edited April 2005
    Boy, this is getting expensive. He started out looking for speakers under $700 and we're up to $2500-$6000 already! Do I hear $7000! :D
    VR3 Posts: 29,440
    edited April 2005
    Def Tech BP10B 300-450 + S
    Def Tech BP30 - 600-700 + S
    (EBAY)
    Their not for the lazy at heart, require alot of work, but once you got them setup...WOW...
    And I also recomend the B&K PT5 and the ST 125.2
  • dkg999
    dkg999 Posts: 5,647
    edited April 2005
    Magnepan MMG's, the $550 entry level pair. Invest in some good stands, a decent amplifier, and wow! Other than that, a used set of Dynaudio 50 or 52, and a really good amplifier.
    DKG999
  • khanhhuynh4u
    edited April 2005
    lol thanks alot for all the opinions guys but i dont think i could afford anything more than $1000 for now since im in college but one day ill own something that nice but for now im still on a tight budget....
    ill guess im going to start saving about 100 bucks a month and starts from there but....about how much should i save to get something that's begins in the high ends system?? should i go digital also?? worth it??
    what im worrying most is spending that much money and not getting what i wanted...with the RTi4 right now i still feels empty somehow, so do you guys think it should help if i added an onkyo M282 amplifier to the onkyo 8211 reciever, will it makes it clearer or just louder??
    im just beginning to take music seriously so any help or suggestion from you guys are greatly appreciated.
  • dragon1952
    edited April 2005
    Welcome to the club, buddy.....you have just begun the journey. :cool:
  • scottnbnj
    scottnbnj Posts: 709
    edited April 2005
    bring a wide variety of your own tunes with you when you demo.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited April 2005
    I'm a one-trick pony here. Vintage Polks, with upgraded tweets if not coming with Peerless; bang for the buck, and neato factor, is outstanding. Good luck.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • gregure
    gregure Posts: 871
    edited April 2005
    Your current RTi 4's would undoubtedly sound better w/ more amplification. Try to find something nice, maybe a used amp, or a couple of monos from Outlawaudio.com.
    Better amplification always makes a speaker sound better, no matter which type. If you want to go LSi, tho, you really should save up a couple thousand to run them on something good. Again, the B&K two-channel PT5 and matching amp would be a great choice. Warm sound, and best performance at that price.
    Current System:
    B&K AVR 507
  • khanhhuynh4u
    edited April 2005
    ok ill think ill stop spending after getting a good amp and start saving...im not a very good shopper at getting great deals but someone knows any good amp that i should look at? or any know any used amp that are a pretty good deal? i got all my stuff at fry's electronic and their stuff are not good with music choices but hey im beginning here but thanks guys for all the help....lastly i got the speakers for 260 and receiver for 150 so i guess an amp shouldnt go over 300 or so since its not even considered mid-end yet lol so no one recommend me an amp thats a 1000 buck or so....I CANT AFFORD IT!! haha
  • khanhhuynh4u
    edited April 2005
    oohh sorry for the add on but is the onkyo 8211 a good receiver for the RTi 4 or does it need something a little better...i mean i dont listen to it very loud but does a little nicer improvement make it better? also where to shop online to shop for the amps? i saw alot but crutfield and vanns seem most reliable to me...
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2005
    This is why you need to do one of the best thing in audio; go to different shops and play with all the wonderful toys! :D
  • gregure
    gregure Posts: 871
    edited April 2005
    Not sure of the ratings on the Onk 8411 but a good 100 wpc stereo receiver from Onkyo, Denon or HK would be a good price-friendly starting point.
    Current System:
    B&K AVR 507
