glass optical digital cable
danger boy
I'm in the process of getting rid of some of my lesser quality IC's, speaker wires and digital cables.
I just bought a glass optical cable off ebay for about $34 for 1M. I hooked it up to my recevier from the optical output from the Dish Network receiver. I'm not going to say it sounds amazing and is a huge upgrade from the Monster cable I was using.
But i did notice (slightly) better seperation and clarity in the sounds. Where i noticed the biggest difference was when listening to those Sirius music channels on Dish Network. the bass is much more pronounced. I had to double check to see if my sub was on or off. The SVS was turned off.. and the bass was quite a bit better with the glass cable.
It may be hogwash.... but I figured for $34 i'd give it a try. One cable down.. 9 more to go. Whew, i'm exhausted.
PolkFest 2012, who's going>?
Post edited by danger boy on
You got a link or a picture of that glass cable? I've never heard of such a thing. It sounds interesting.Bob Mayo, on the keyboards. Bob Mayo.
Oh. Is the difference with that cable supposed to be with the actual fiber optic material?Bob Mayo, on the keyboards. Bob Mayo.
yes glass fiber optic instead of plastic fiber optic. suppose to reduce jitter as well.PolkFest 2012, who's going>?
Ok. I never really thought about that before. I just kind of figured that there was only one material for fiber optic material.
Decent price. I think you're right in giving them a try.Bob Mayo, on the keyboards. Bob Mayo. -
I had the same type of experience when switching optical cables from a brand we don't mention to Outlaw Audio. The sound quality, soundstage, and clarity all improved. My perception is that the db level went down for a specific volume setting on my Yamaha 5790 receiver. In a previous post the prevailing opinion was that since this is just the transmission of 1's and 0's, the cable should not impact the sound. Not being a rocket scientist, I'm not sure whether my perception was biased because I spent money on the new optical cable, or if there really is a difference!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
dkg999,
how do you like that Cambridge CD player you have there? Are you using an optical output to a DAC with it, or just using the player by itself.
I will be in the market for a new CD player in about 8-10 months. That Cambridge has always looked interesting to me. Audioadvisor.com sells it for $500, and I'm sure I could probably find a used one for less.
Any thougths?Bob Mayo, on the keyboards. Bob Mayo. -
gmorris - I absolutely love the Cambridge Audio CDP! I am using the DAC's in the CDP and running the analog output into my Parasound P/HP-850 pre-amp. I bought mine as a showroom demo. for $399, but I don't think it had much use, as it took about 50 hours of playing time for the DAC's to smooth out. It seems to be very solid and works great. I am thinking about getting the Musical Fidelity tube buffer/DAC and using with an older Onkyo Integra 6 disc. changer to see how that will compare with the Cambridge Audio. I just keep finding other things to spend money on and haven't gotten to this yet. If you want to use an external DAC, the Cambridge 540C I believe uses the same transport as the 640C, but doesn't have the Wolfsen 24 bit DAC, and is significantly cheaper.DKG999
