Power amp wires..where to?
JDMCivicB16B
JDMCivicB16B Posts: 67
edited April 2005 in Car Audio & Electronics
well..i am having a little difficulty. I figured out the power wires go into a dist. block..to the amps..but where do the power go to? the battery under the hood? and how do i hook it up to my stock battery?
'95 Civic EX
dbs in front stage
Type-Rs in back
MTX T202
10inch PolkMOMO sub
Kenwood HU
Kenwood KAC amp
'00 s2k ....
Pioneer AVIC-N2
MMC6500 x 2
JL 300/2
(still pending..)
2003 XL DeNali
(the wife's new ride)
..new project..wife comes first before s2k
Post edited by JDMCivicB16B on
  • swerve
    swerve Posts: 1,862
    edited March 2005
    take it to circuit city and let them do it for you.
    then once you see how it's done... you'll know for the next time.
    :D
    -adam
    cats.vans.bag...
  • exalted512
    exalted512 Posts: 10,735
    edited March 2005
    i got a ring terminal for the right size power wire i had and hooked it up with the rest of the wires at the battery
    -Cody
  • swerve
    swerve Posts: 1,862
    edited March 2005
    -Cody
    something about your post makes me laugh.
    -adam
    cats.vans.bag...
  • JDMCivicB16B
    edited March 2005
    oh thats right..circuit city does have a install bay. yea i guess i let them do it. thanks
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    Dont waste your money.
    Do like Cody said. Get a ring terminal and run your power wire from the dist block to the battery. Make sure you stick a fuse within 18" of the battery and before it passes thru the firewall.
  • JDMCivicB16B
    edited March 2005
    so i should wire it to a empty hot spot on the fuse box..and then run it to the battery?
    i know the ring terminals you are talking about.i bought an amp kit..that came with them.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • MacLeod
    edited March 2005
    No you use a fuseable link. Like this one.
    From the battery you run the power wire to the fuse, then thru the firewal to the dist block then from the dist block to your amps.
    Nuttin' to it.
  • JDMCivicB16B
    edited March 2005
    ok i can understand that, that sounds simple. I have another question. Where is the best place to ground? and i am going to need 2 dist. blocks, one for ground also?
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • MacLeod
    edited March 2005
    You dont need a ground dist block but they do make things neater and more secure so theyre never a bad idea.
    For a ground, ideally use a seperate location for each amp. Find a good piece of metal under the carpet somewhere and sand all the paint off and then drill a hole thru it (make sure there isnt a gas tank or brake lines on the other side!!). Then use another ring terminal and bolt it thru there.
  • JDMCivicB16B
    edited March 2005
    so Ground it to the chassis? and How does a ground dist. block help out?
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • MacLeod
    edited March 2005
    Well, if youre going to have a single ground running to 2 or more amps it makes the connection a little more secure as opposed to simply splicing the wires together.
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2005
    you don't necessarily need to drill a new hole... for example, i'm grounded to a seatbelt bolt (and it's pneumatic-wrenched in WAY beyond all sane amounts of torque :)). and, ground distros help because it can get entertainingly difficult splicing 2 4-gauge wires together, not to mention 3 or more.
  • MacLeod
    edited March 2005
    Thats what I did.
    Both my power wire and ground are all spliced.
    I took the 4 guage power and stripped it down about 4 inches then strippid off about 6 inches on each 8 guage power wire and then wrapped them around the 4 AWG wire then taped the hell out of em with duct tap. In 15 years I have yet to use a distro block and havent had anything catch on fire! Except for the time I used cheapo Radio Shack 10 AWG and it shorted on something under the seat!
  • neomagus00
    edited March 2005
    mac, that is honestly the most ghetto thing i have ever heard of. you are my hero.
  • JDMCivicB16B
    edited April 2005
    Also..i bought a LCD screen online..waiting for it to get here..i want to pre-wire it..how do i get power to it? and how do i wire for a video and audio signal? i am going to put a ps2 to it also.
    '95 Civic EX
    dbs in front stage
    Type-Rs in back
    MTX T202
    10inch PolkMOMO sub
    Kenwood HU
    Kenwood KAC amp
    '00 s2k ....
    Pioneer AVIC-N2
    MMC6500 x 2
    JL 300/2
    (still pending..)
    2003 XL DeNali
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2005
    Hehe.. Mac, that reminds me of an install I did.
    The person wanted cheap install, so that's what I gave em. and when their amp wire was too short, I used some scrap I had of similar 8GA. I joined them by opening up the strands then wiggling the ends into each other about half an inch. That got E-taped and worked great. I told her "dont pull on it, no matter what!"
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • MacLeod
    edited April 2005
    Eh. I didnt have the cash for the distro block not to mention the room to mount it. I guarantee you my connection is just as good as any distro block could be and with the amount of tape I used there is no chance of if shorting out due to scraped off insulation.
    Plus, Im not a big fan of showing off wires. Right now my install looks like **** but once I get my sub, box and amp board built, the only wires youll be able to see will the 2 inches or so of wire that comes thru the ampboard and into the amps.
    And actually I have invisioned making some kind of cover that I can set on top of the amps so only the top half of the amps, above the wires connestions, are visible. I know this isnt anything revolutionary but if I can pull it off with my limited skill it will be! ;)
  • neomagus00
    edited April 2005
    oh, come on, we all know you can do this :)
    still a good idea, though, even if it's not original. i personally like showing a bit of wire, if it's done neatly and on purpose; like arranging the speaker wire on inverted subs, or having all the wires from the amp fan out and then disappear. either way is good.
  • MacLeod
    edited April 2005
    And there is nothing I hate MORE than inverted subs! :mad:
    Stick the damn things in the box the way they were meant to be!! And pull your damn pants up!!
  • neomagus00
    edited April 2005
    haha... it's okay, i wear a belt. and the sub in my room is inverted because i built the box too small... i would never do that to a real sub.
  • LittleCar_w/12s
    edited April 2005
    Just out of curiosity, neo, how does inverting the sub do for the sound :D
  • MacLeod
    edited April 2005
    It does basically nothing. Its just for looks.
    People who invert their subs are the same people that buy Audiobahn equipment! :p
  • neomagus00
    edited April 2005
    hey, that was uncalled for!
    and it actually does nothing to the sound, you just get more space in the box (for me, more air and no polyfill sounded better than less air and more polyfill).
  • MacLeod
    edited April 2005
    Originally posted by neomagus00
    for me, more air and no polyfill sounded better than less air and more polyfill.
    And a properly built box in the first place with the sub INSIDE like its supposed to be is even better! :D
  • swerve
    swerve Posts: 1,862
    edited April 2005
    *spouts off the infamous MacLeod box joke!*
    heh
    cats.vans.bag...
  • MacLeod
    edited April 2005
    heh
  • AustinKP
    AustinKP Posts: 861
    edited April 2005
    Little late, but there is a good way to know if you have a good ground location. Take a voltmeter and place it across the battery terminals. It'll read something like 12.8 volts. Then to find out if you have a good ground location in the trunk or whatever, place the voltmeter leads from the + power wire to the potential ground location. It should read the same voltage. If it's less, you need to scrape off the paint, or find a better location.
    -Austin
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • MacLeod
    edited April 2005
    Ahhh, I never though of that. Good point.
