Hand Made In The USA...and my hands HURT! ouch
VR3
Yep, I finally gave this a shot..
I need to sand them, which I will have to borrow...but...I cut it out with the table saw...and filed the corners down to size, and cut the holes on the bottom with a screwdriver...
They fit incredibly well...
I plan to paint the edges with truck bed liner and stain the tops...
Very freakin' nice dude! Great job with the saw for sure. But pardon my ignorance...what are they?
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Def Tech BP10B Cap -
Mine arrived damaged...someone in Kansas is making me a set, but I wanted to make my own!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Awesome dude!
Thanks..
Now I just need to borrow a sander...
sand down the ends a lil and get it more to size...
the corners are slightly big, but like I said - a lil sanding with take care of that...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Look pretty good to me there lil bro.
Damn you've gotten really good with woodworking. Impressive!
As with most jobs, the right tool for the job is always a necessity. -
Thanks Paul...
As for the right tool for the job...man I wish! lol...
Check out my 'file' - this worked down those corners... LOL
And the 4 holes on the bottom of the caps were done with a flathead screw driver and a hammer...
The cuts were done with my table saw out in the garage...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well,
Sometimes you just have to "make do" with what is available.
Your ingenuity, hard work, and attention to detail will get you far in life. -
Thanks...and yep, make do is what I gotta do I suppose...
Now...Any ideas on how to cover the top while I coat the edges with spray paint and truck bed liner??
My thoughts was masking tape and paper maybe...but would this hold up to the spray paint and truck bed liner???- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ummmm.....I'm not the brightest carpenter on the job, but isn't that like a fish scaler or something
Hell, I thought is was a fingernail file...couldnt tell ya...
All I know is...it worked!
Very nice woodwork, sid. But... I just have to ask... what is it with you a spray-on truck bed liner? I mean, it's durable, but does it really need to be?
Personally, I'd leave em unfinished, with maybe a clearcoat to help protect. But, it is your project and you can do with it whatever you please.
Again, nice work, especially considering the tools.
Edit- I just noticed that you said you were painting the _edges_ and _staining_ the top. Sounds good
Ludicrous gibs! -
Yeah, that should work. Use an exacto knife or razor to cut the rounded corners out of the masking tape so that you have a clean sharp edge.
I guess you are worried about getting spray under the masking tape? Try spraying down at a 45 degree angle instead of straight ahead. -
Thats a good idea Paul....
How about 45 degree angle...spraying with the tape and paper...I think that would work...hmmmmmm
I dunno, I'm not to worried about smoothing out the sides, truck bed liner is rough...I'm more so worried about the top...
See...
A guy in Kansas is making me new top and bottom caps out of real wood, and is staining them Rosewood....
I plan to stain the top of these in oak...
And I plan to sand down the old/scratched caps and send them to the guy in Kansas for a new high gloss black finish...
This way, when/if I sell them - I'll have high gloss black, oak, and rosewood...
may make some cherry caps too- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Spray down like the previous poster said, and use a round metal rod of some type to burnish down the edges of the masking tape so that it is sealed good. The blue 3M auto body masking tape might work better, but it is kind of expensive for just one project.
Nice work!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
truck bed liner is on...
24 hour drying time...
then stain (clear coat)...boom boom, 1 cap complete...1 more to go!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
hmm...
I went ahead and clear coated the top...
I don't think I will make another one though...I will just chaulk this up as a fun project...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
closer view...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
It's the bed liner trim that is sucking wind...do more with just the clearcoat brother, they look good!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The problem with just clearcoating that is that you have all the horizontal laminate levels showing which looks cheesy.
Personally, I don't like the truck bed liner in the mix either. There's no fluidity in the fabric, side, and top of the cap. It looks too busycomment comment comment comment. bitchy. -
sid , there is iron on laminate that you can put on the edge of the plywood, its made by bandit and real easy to use just iron on and trim with a razor. looks real good to, you should give it a try.
Well....
I wish I knew how to do a high gloss black finish...I'd do that...
I don't like the truck bed liner either...hmm...
It was a fun project though...atleast I know I can make the caps...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
