Which receiver to get?
PremierVenge
PremierVenge Posts: 11
edited March 2005 in Electronics
2 R50 Fronts
2 R30 Surrounds
CSI30 Center
PSW303 Sub
Can any of you recommend one of the following receivers for this system?
Denon AVR 1705
Denon AVR 1905
Onkyo SR502
Onkyo SR602
THis is going in my basement that is approximately 14 x 12. I know this is not the highest quality polk system on the market but it is very suitable for my needs. This will be my first ever home theater system so I have no clue as to what type of receiver I need.
Thanks in advance for the help!
Paul
Post edited by PremierVenge on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited March 2005
    My choice for your system would be the Denon 1905. It is a good performer for the money, especially if you get it as a refrub from ubid, ecost, or pcmall.
    It also has preamp outputs if you ever decide to upgrade to speakers that need an external amp.
    Another nice little perk of this receiver is the component video upconversion.
    Tschüss
    Zach
  • Whadyasay
    Whadyasay Posts: 300
    edited March 2005
    Might want to look into this one as well. You get a lot for its price:
    http://reviews.cnet.com/Pioneer_VSX_1014TX_K/4505-6466_7-31000741.html
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • ezc
    ezc Posts: 426
    edited March 2005
    I would go either with the 1905 or the 602. Both are good receivers & should drive your speakers well.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited March 2005
    If you can afford to spend more, get a receiver with preamp outs. The Onkyo 702 is the cheapest model with that function. I'm not sure where in the line that Denon brings that into their models.
  • Toxis
    Toxis Posts: 5,116
    edited March 2005
    1905. I also suggest this one.
  • PremierVenge
    edited March 2005
    Pardon my ignorance...but what are the preouts for?
  • McLoki
    McLoki Posts: 5,231
    edited March 2005
    They allow you to run an external amplifier from your reciever. You would then plug your speakers into your amplifier.
    i.e. - you are now running 5 speakers (forget the sub for this demo...) from your AVR. You decide to blow your tax return check on a really large set of front speakers. You could purchase a nice used 2 channel amp to run your front speakers (hooking it up throught the front right and left pre-outs on your AVR) and run the rest of your speakers from your AVR.
    Michael
  • Shizelbs
    edited March 2005
    It makes it so that when you want to upgrade to new speakers, that also need a better amp, you can still use the receiver to do all the Dolby Digital surround stuff, among its other features.
    Basically, it makes it more upgrade friendly.
    I mentioned it because thats been my biggest regret so far. I started pretty much exactly as you are. I just wish I had purchased a receiver with preamp outs.
  • umkalyan99
    umkalyan99 Posts: 9
    edited March 2005
    I am also a newbie, I have a question, there are recievers with direct 2ch stereo capability ( yamaha, marantz.. etc), In that case a preout is not necessary isnt it?
