sub wiring
Frontier
Ok will someone help me get some numbers down, i have two mm2124' in a dual sealed box .88cu^3 per sub bla bla bla. what i was going to do is buy two c500.1 monos 1 for each but then i was thinking about it and looking at wiring diagrams and found out that i could run both subs off one c500.1. Now do i really want to do that? money is of no concern! so with all this info please tell me what you KNOW..... Also by numbers i mean what my ohms are going to be and watts RMS. Thank you
-Austin
-Austin
Frontier
Post edited by Frontier on
if you had the DVC models, you could run a 500.1 to each and be good. the 300.2, bridged, is too powerful unless you set the gains carefully. and the 400.4 isn't powerful enough, so you'll probably want to go with another company for amplification. Find an amp that makes 800 W x 1 Ch. @ 2 Ohms, or 400W x 2 Ch. @ 4 Ohms.It's not good, very fundamentally simply not good. - geolemon
