C300.2 of C400.4 for mmc6500?
SamSagaZ
SamSagaZ Posts: 321
edited May 2005 in Car Audio & Electronics
well, i think that the best choice are the c300 what do you think guys?
Post edited by SamSagaZ on
  • exalted512
    exalted512 Posts: 10,735
    edited March 2005
    the 400.4 will offer better adjusting capabilities. id personally get the 300.2 but i can tell you that macleod would get the 400.4. i prefer the straight forward install of a 2-channel
    -Cody
  • SamSagaZ
    SamSagaZ Posts: 321
    edited March 2005
    i think that with the c300 ill get less distorsion, and maybe a little better SQ.
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    The only difference between the 300.2 and the 400.4 would be youd have a lot better tuning abilities for the tweeter with bi-amping.
    Im sold on bi-amping. Im a firm believer you will always get the best SQ from bi-amping.
    But Cody has a point. Straightwiring is a lot easier and cheaper and wont sound bad by any means. I just like the extra tweaking ability.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited March 2005
    so you say that if i can, just buy the c400.4 instead the c300....
    but if i buy any of these amps, ill get an good sound.
  • AustinKP
    AustinKP Posts: 861
    edited March 2005
    You've got it. :)
    -Austin
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • exalted512
    edited March 2005
    to sum it up
    upside
    400.4 could give you better slightly better sound quality
    downside
    its more expensive (more speaker wire and i believe the amp itself is more expensive)
    takes more time to get it sounding right
    harder to wire
    300.2 is basically the opposite of the 400.4
    -Cody
  • MacLeod
    edited March 2005
    Definitely. You wont go wrong with either.
    The MMC6500's are more plug and play friendly so straight wiring will be fine. The MM6 however require a lot of tweaking I think. I tried them SW and I think the way Ive got them tuned now is 100 times better than going 2 channel.
    Bottom line:
    If you want more of a plug and play set up and dont want to mess with extra cables and dont really care about obsessive tweaking then 2 channel is the way to go.
    If youre like me and are never done tweaking your speakers then 4 channel may be a better option.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited March 2005
    ok :)
    thanks guys.. latest question on this thread... when you say bi-amp, u mean using one channel for the tweeters and the other for the mids?
  • MacLeod
    edited March 2005
    Yup.
    Usually youll run the fronts amp channels to the tweeters and the rear amp channels to the mids.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited March 2005
    well but i dont will get enough power for the mids! 75watts for each mid is not enought.. and 75 for each tweeter is a lot :D
    i think that ill lose a lot of power biamping with the polk amp...
    and i have a lot of things to tweak the setup, amp, head unit, speaker crosover... i think that its enough :D
    right?
  • MacLeod
    edited March 2005
    When you run 150 watts to a tweeter and mid component set, 75 goes to the mid and 75 goes to the tweeter.
    The 400.4 puts out about 90x4 so be very careful with the gains. Those speakers aint the Mighty MM6, theyre only rated at 120.
  • Systems
    Systems Posts: 14,873
    edited May 2005
    So if one had a MM6 system on the front doors, the C400.4 would be a good bet?
    What if a MM6 system was installed in both the front and the back doors? Would two C400.4s be too much or just right?
    Thanks for any input.
    -X
    Testing
    Testing
    Testing
