box question
sntnsupermen131
im pretty sure you cant do this but i want to make sure
if you have 2 mm120s can they be in the same box with out seperate chambers??
if so how much air space would you need?
-cody
-cody
Post edited by sntnsupermen131 on
thanks kim
that makes it a whole lot easier!!
-cody -
Run an amp in brindged/mono mode also so you do not have the subs fighting eachother.
