Need advice on my 2-chanel system
PRC
PRC Posts: 58
edited March 2005 in 2 Channel Audio
I am new to the sterio market. I primairly play music. I have recently purchased a Yamaha RX-777 reciever and a set of RTi8's. I also have an entry level Polk Sub - PSW202.
I really like this set up. Here is my delemia. I would like the system to sound a little more crisp and clean. A friend of mine -who's opinion I respect - suggested that I am not really using the RTi's to their full potential. He suggested (2) Outlaw Mono-block 200 amps. He said try this first before changing speakers or other components. I am looking for some feedback on if this is my best solition. I am also an a budget. Thanks. PRC
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Post edited by PRC on
  • hoosier21
    hoosier21 Posts: 4,413
    edited March 2005
    adding separate power amps should improve the sound of any system, and the Outlaw mono's are a good start.
    Have fun, the spending has just began ;)
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2005
    I recommend you take the sub out of the system. They can blur bass and make the midrange too thick if not high quality and setup properly.
    I tried to incorporate a very good SVS into my 2-channel, and didn't like the outcome.
  • shack
    shack Posts: 11,154
    edited March 2005
    My experience is exactly the opposite. I use a good sealed (not ported) sub and really like the results. The the key word his is "good". I've owned 2 of the PSW202s and IMO they work ok for an entry HT set up in a small room but I would not use one in a 2 channel music system. They tend to be a little boomy and I tried several tweeks like additional polyfill and stuffing the ports...which didn't really help. If the 202 is all you have...take it out of the system...but don't rule out trying a better sub such as an Adire, SVS, HSU or Dayton.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2005
    Welcome PRC.
    By all means get a couple of Outlaw Mblocks & watch your speakers come alive! They are only 299.00 But see if they have any for sale in B-stock which will get you some a little cheaper.
    http://www.outlawaudio.com/mofcart/bstock.html
    Let us know what you decide.
    Cathy
  • Toxis
    Toxis Posts: 5,116
    edited March 2005
    That would be a great start for $600 but there's a lot of options out there. I bought a used 7 or so year old Rotel stereo amp for $265 (120x2) and absolutely love it. Don't hesitate to look into the used market. Ebay and Audiogon can be friends if you know how to use them.
  • PRC
    PRC Posts: 58
    edited March 2005
    Thanks I appreciate the imput
    Canton Ergo 900 DC
    Polk PSW404
  • PRC
    PRC Posts: 58
    edited March 2005
    Thanks everyone for the imput
    PRC
    Canton Ergo 900 DC
    Polk PSW404
  • Shizelbs
    Shizelbs Posts: 7,433
    edited March 2005
    The used market can be your wallet's friend.
    My current system contains nothing purchased new by me. I love it.
