Hello, and help
Spawndn72
Spawndn72 Posts: 453
edited March 2005 in 2 Channel Audio
Hello everyone, I have decided to put togther a 2-ch system. I am new to most of this, and on a whim I bought a pair of monitor 7 speakers on ebay today. So that is the start of my new system. I am on a tight budget and need some advice on componets to go with these speakers. Looking around on ebay I see that I can buy older amps and pre amps (adcom, rotel) for little of nothing; 100-150 or so. I have a new pioneer dvd/scad/dvd audio player so that part of the system is covered. I will be using this system in a small apartment. And my taste in music is pretty diverse, everything from metallica to Opera.
Ok, that is the background, now for the questions. Anyone got any recomendations. Usefull info would be things like minimum power for the amp. Brands to look at, brands to steer clear of and wether I should be looking at seprates or integrated units.
Thanks for your time.
Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Pioneer DV-578A Multi-format
Polk SDA-2 Mains
Post edited by Spawndn72 on
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2005
    Take a look in our flea market, there are a couple things that would work out just peachy for you. There is a Nakamichi RCV for sale....old school power for an old school speaker.
    Excellent speakers BTW....and where are you located?
  • Spawndn72
    edited March 2005
    Bradenton, FL (just south of Tampa)
    And thanks for the suggestion. I will go check it out.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Polk SDA-2 Mains
  • George Grand
    George Grand Posts: 12,258
    edited March 2005
    Onkyo or Carver power amp. One of those Adcom pre/tuners, you're all set.
