Center for R30s
Flak
Flak Posts: 3
edited March 2005 in Speakers
I know polk says the csi20 is the best match. But just one mid and low sensitivity scare me away from the center. I haven't heard any of these centers, but I'll trust your judgement even if it is for the csi20. Here is what I've found that I can get:
csi20 - $107
csi3 - $139
cs1 - $179
Thanks,
Flak
Post edited by Flak on
  • organ
    organ Posts: 4,969
    edited March 2005
    The 20 will match your R30's best. The CSi3 and CS1 have different drivers and tweeters than your R30's. If you feel you need a powerful center and don't mind the slight difference in tonal balance, go ahead and get the 3 or 1. Maybe you can go for the CSi3 if you plan to upgrade to the RTi in the future.
    Maurice
  • organ
    organ Posts: 4,969
    edited March 2005
    Forgot to mention..... WECOME to the forum!:cool:
  • gwh
    gwh Posts: 1,451
    edited March 2005
    Try the 20, if you don't like it sell it in the Flea Market section.
    G
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
  • jkhering
    jkhering Posts: 3
    edited March 2005
    I use the CS1 with my R30's and I'm very happy with it. I have the center volume turned down -3db via my receiver because it seems to me to be a little more in your face than the R30's. After making that adjustment, they all sound great together.
    Also, I was able to get the CS1 for only $125 at Circuit City by having them price match HHGregg's price of $130. If you buy at Circuit City, you also get 30 days to return it if you decide you're not happy with it.
