Audioquest Sorbogel big feet
haimoc
haimoc Posts: 1,031
edited March 2005 in 2 Channel Audio
Does anyone have experience with using these feet or similar products? I'd like to hear your opinion about these products. Thanks.
Post edited by haimoc on
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2005
    I've used Vibrapods in the past with good success, under my CDP.
  • haimoc
    haimoc Posts: 1,031
    edited March 2005
    Thanks, Steve.
    I found some good reviews on Vibrapods, too. Some said to put 3 feet (instead of 4) under the player for better stabability.
    F1nut Posts: 50,546
    edited March 2005
    Big Feet work very well, highly recommended.
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2005
    They were a waste of money for me.....quickly returned them.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited March 2005
    Vibrapods are the best bang-for-buck 'soft' decoupler/isolator.
    I prefer 'hard' isolation components. Brass cones, wood blocks, sand filled platforms, etc. All your CDP is going to do on AQ Big Feet is jump around like a **** in the bouncy balls.
    Cheers,
    Russ
  • steveinaz
    edited March 2005
    I had a strange epiphany while experimenting with Vibrapods and Mapleshade brass cones.
    The Vibrapods made the player sound too lush, and the Mapleshades were a touch too analytical. The stock feet are now back on my CD Player. They're hard plastic with a rubber insert---maybe the perfect balance?
    I don't know why I bother with isolation anyway, I've got a concrete slab house. The only vibrational energy I have is airborne.
    VR3 Posts: 28,641
    edited March 2005
    My floor is a trampoline...
    I need more than vibrapods...
    I need my CDP on fishing line hanging from the ceilling with about 10 layers of foam around it...
