portable dvd player suggestions
re510
re510 Posts: 29
edited March 2005 in Electronics
im thinking of getting a portable dvd player for a trip and was wondering if anyone could suggest which brand. I'm thinking of a 7" screen and under 300 dollars probably get one from the bay.
Thanks in advance
System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Post edited by re510 on
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2005
    CC has a 10" Polaroid for $349. Dual headphone jacks, in/out capability, screen flips around and upside down, car jack, and a partial protective case included.
    http://www.circuitcity.com/ssm/Polariod-10-Portable-DVD-Player-PDV1002A-/sem/rpsm/oid/117693/rpem/ccd/productDetail.do
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2005
    I bought 4 of the 7 inch Polaroid models from Walmart this past Xmas and find them to have all the options you could ask for.
    They were only $140 to boot. I wouldn't put alot into something that will get knocked around as much as these will.
    DG
  • jarros
    jarros Posts: 84
    edited March 2005
    I picked up a Panasonic DVD-LA95 before last Christmas for a 25hr road trip (each way). It's got a 9" screen and works GREAT. I managed to get it for under $300 used with accessories on the bay.
    Before buying the unit, I did a lot of research to find out which one would work best for me. Be careful, a lot of the cheaper name brand units (Mintek, Polaroid, Initial, etc) are cheap for a reason. They may look decent initially, but a lot of those units have reliability issues. Be sure to read a LOT of reviews before making a purchase.
    HT Setup:
    Pioneer VSX-D912K
    Polk CSi30 Center
    RM6005 Satellites (Fronts/Surrounds/Rear Center)
    Nameless 10" Sub
  • Toxis
    Toxis Posts: 5,116
    edited March 2005
    I really like the Panasonic's when it comes to quality and not being to overpriced. The Toshiba and Sony's are really nice but dear god... PRICEY MUCH?
