Monitor 7 surround sound question.
jgs2n
jgs2n Posts: 2
edited March 2005 in Speakers
I posted this in the vintage speaker forum without any response. Any advice on this would be appreciated. I am a novice on the home theater front. I like my old monitor 7's and am cheap. Would these work with any of the csi center speakers or would I be better off scrapping the old speakers.
Post edited by jgs2n on
  • scottnbnj
    scottnbnj Posts: 709
    edited March 2005
    seems like smaller vintage monitors in the same series (same drivers) as your 7's would be the natural choice. you should be able to find them used here in the flea market or on e-bay if you are patient.
    if you can't figure out which of the smaller monitors are the best match, posting pics of your 7's might be the most direct route to help folks figure out exactly what you have and need.
