New Version Dared Tube gears ?
tapeshc
checkout this
Dared New SL-2000A Tube linestage preamp
Dared Amp VP-20 monoblocks
Sounds like a very good value for money.
Anyone has ever heard or owned these ?
It seems they are using pretty good components so if the design is good, they should sound pretty good.
Tapesh
Tapesh
Post edited by tapeshc on
I've been using a Dared SL-2000a for over a year and it works extremely well. It's a very inexpensive pre that works well with both tube and SS amps.
Frank,
do you have one of these with Auricaps or without Auricap.
I mean if they sound good without Auricap, possibly the new ones will sound even better
Recently I got ASL AV-25 and they are awesome, believe me they are. Now pepole suggest they they improve even more with Auricaps in them.
Thats why I was little more excited to try these as they already have good quality component.
The only hesitation is that it has only two inputs.
Regards
TapeshThanks
Tapesh -
I don't think so. the 2 inputs doesn't bother me really. I have a DVD/CD player and a tuner connected to it and that's really all I need.
