Dual TT Issue
KCF
Any TT users out there familiar with Dual 506 or similar models? Since resurrecting this oldster, works well with new belt, only just recently find that the tone arm doesn't lift at the end of play, just sits bumping in the groove. Anyone know a fix?
K.
K.
Post edited by KCF on
Check this Dual link for lots of info. Had the 508 and am using a CS-741Q. The lift mechanism should trip a lever causing the arm to lift. Open her and see if that when the arm moves to the outer groove that something happens. Good Luck.
I'm using a 510. Great little table for the money. I agree with tonyv1. It's probably a simple to fix mechanical issue that for some reason isn't engaging.Make it Funky!
