How to plug stuff in...
rnp614
I have a Rotel RSP-980 I use as a stereo preamp and it has an outlet on the back. Is it ok to plug my amp into there so I dont have to switch them both on separately or should I plug the amp into a separate wall socket?
Thanks in advance!
Raj
Thanks in advance!
Raj
Post edited by rnp614 on
Don't plug anything into your preamp or receiver that draws significant current. Therefore, plug the amp into the wall outlet.
+1.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
-2Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
=-1Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
nice math fellas!
2+2=22
I plug my amp into the fridgerator
Have fun!
*jammin Sid*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Originally posted by Vr3MxStyler2k3
2+2=22
Have fun!
*jammin Sid*Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Quite the contrary...
The whites get really cranky while the colored clothes make oos and ah noises in the spin cycle...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Now if I can figure out why the tires on my bike don't hold air...Never kick a fresh **** on a hot day.
alrighty then! (Must remember to check for full moon):DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Is that what you call it?
I knew I saw something funny outside...turns out it was just my neighbor...
However...
Now days I think they call that -indecent exposure-
As for your tires Toxis... Blame the penguins...the penguins I tell you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
As for your tires Toxis... Blame the penguins...the penguins I tell you!Never kick a fresh **** on a hot day.
