Garage sale finds part 2
gwh
gwh Posts: 1,451
edited March 2005 in Electronics
Any info as to time frame, specs, value, would be appreciated.
1. Lafayette stereo 250 A tube amp
Plugged amp in power indicator did not light.
Two outer knobs missing. Cost...$3
2. Harmon Kardon model SR 900 receiver.
Plugged in lights up, need to get some fuses before I wire up some speakers. Cost ...$15
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • gwh
    gwh Posts: 1,451
    edited March 2005
    HK
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited March 2005
    The little HK bumps, hooked it up to the Norman Labs I bought on another GS outing.
    Getting some static out of one channel when I adjust the volume, tap the volume control after adjusting and the static goes away. Easy fix ? The stereo indicator light is out , Radio shack for replacement bulb?
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2005
    Turn the unit off, and work the pots back forth rapidly. ALL the pots, tone, balance, etc.
    If that doesn't do the trick, you can by a can of Deox-iT, or contact cleaner at Radio Shack and spray the pots (unit OFF) and work them some more. (you may have to remove the facia, if you can't get to the pots through the top).
    Allow for time to dry, and clean up any excess before powering the unit back on. Repeat as needed, until all the scratching / static is gone.
    Cheers,
    Russ
  • gwh
    gwh Posts: 1,451
    edited March 2005
    Thanks for the info. I'll hit RS tomorrow.
    I think I've found a new hobby besides laying in the recliner and scratching my nads.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • George Grand
    George Grand Posts: 12,258
    edited March 2005
    Nice little scores. In another life, or so it seems, I worked for Lafayette Radio Electronics in the Hauppauge, New York warehouse.
    George Grand (of the Jersey Grands)
  • wlrandall
    wlrandall Posts: 440
    edited March 2005
    Contact cleaner is great stuff, but for pots I still use their TV tuner cleaner. It contains a real light lube that will keep the contacts form scoring each other.
  • gwh
    gwh Posts: 1,451
    edited March 2005
    That’s cool George, any idea when this model was produced?
    I know it was probably before your time.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited March 2005
    wlrandall,
    I'll check that stuff out too.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited March 2005
    Crapola!
    That tube amp fetched $87 on the bay.
    Now my question is: Now and then I run across those old combo record player/tuner combos in the big cabinets for arond $20, I'm guessing at some point in time some had tube amps, right?
    Wonder if those amps would be worth salvaging out?
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • RuSsMaN
    edited March 2005
    Depends on what's in there. The drivers can fetch a little also, with Alnico mag structures.
    Even grunt Tube Magnavox amps, people re-build them into decent sounding 2ch amps.
    Cheers,
    Russ
