Speaker Blown
lloydira
lloydira Posts: 1
edited August 2001 in Technical/Setup
I have a pair of AW/M3II outdoor speakers that are approx 5 years old. They have never been played too loudly. One now rumbles with any kind of bass. What do I do?
Post edited by lloydira on
  • sgtgto
    sgtgto Posts: 310
    edited August 2001
    Hi:
    Try switching speakers and see if the problem is only common to the one you suspect. If it is common to both then you have a connection or some other problem. If it is common to the one that rumbles give it a visual check out, connections and so on. If you cannot find anything wrong in your connections you probably have a bad speaker.
    Gary
  • George Grand
    George Grand Posts: 12,258
    edited August 2001
    If necessary, THAT pair of speakers goes back to Polk in San Diego for repair, not Baltimore. That's the route I had to go. Call Polk.
    George Grand (of the Jersey Grand's)
