"Cheapest" Reference System
Early B.
Early B. Posts: 7,900
edited March 2007 in 2 Channel Audio
What is the least expensive reference system you've ever built (or would like to build)?
To make things interesting, the cost should not have exceeded $1,000 for the main components -- amp, pre, speakers, and source(s). Used prices are cool but vintage gear is excluded (except vintage speakers).
One more question -- how did that "cheap" system sound compared to your current system? Better? Worse? How so?
"God grooves with tubes."
Post edited by Early B. on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited March 2005
    Is that $1000 for each component, or all of them together?
    Tschüss
    Zach
    VR3 Posts: 29,392
    edited March 2005
    HMM...
    If I had to build one...
    Def Tech BP8B - 250
    B&K PT5 - 300
    B&K ST 125.2 - 400
    AMC CD8B - 140
    So...like........
    Total - $1090...SLIGHTLY over, but thats ok...
  • Early B.
    edited March 2005
    Sid - take out those cables and speaker wire and you have some change left. Add it to the source.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2005
    Hmmm...$1000 per component limit:
    Cambridge Audio Azur 640C used as a transport ($600 new)
    Benchmark DAC1 DA Converter ($975 new)
    Parasound HCA-1500A amp ($799 new, now)
    Monolithic PA-1 preamp ($499 new) or use the Benchmark as the pre for FREE.
    ....hmmmm, best speakers for below 1 kilobuck new.....this is tough...
    If I had 1 speaker to pick (new), and $1000.....hmmm...
    Energy Connoisseur C-9
    that was easy, I've only been researching that question for 9 months now.
  • Early B.
    edited March 2005
    If I had to build one, it would be:
    Jolida hybrid int. amp -- $400
    Epos speakers (new) or Polk Lsi7's (used) -- $350
    Cambridge Audio 500SE -- $250
  • Early B.
    edited March 2005
    Okie & Steve -- a TOTAL of $1,000 for all components.
  • steveinaz
    edited March 2005
    Ok $1000 total, new or used:
    Amp: Parasound HCA 1000....$300 used
    CDP: Cambridge Audio D500SE...$279 (new or used now)
    Pre: Parasound PHP-850 pre...$185 used
    Speakers: Athena AS-B2 or Polk Rti6...$225 (new Athena/used Polk)
    there, I got 11 bucks left. And if grab those NEW Athena's on the bay right now for $175....I've got 61 bucks left.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited March 2005
    My current system, I suppose, can be a reference....:D
    Cambridge Audio A500 stereo integrated amp ($250.00)
    Energy Conneisseur C-3 bookshelf speakers (300.00/pair)
    Sony DVP-NS500V SACD/CD/DVD player ($175.00)
    PS Audio 2M Prelude speaker cables ($57.00)
    Standesign BB-75 24 inch metal speaker stands (79.00)
    Vidrapods underneath Sony SACD/DVD player ($32.00)
    All brand-new from authorized dealers. Under $900.00*
    * Can add TEAC Tripath power amp for another $100.00
    Edit: Lots of mention of Cambridge Audio in this thread.
    VR3 Posts: 29,392
    edited March 2005
    Changed it
  • Early B.
    edited March 2005
    Yeah, seems to be the entry components into a higher quality of sound (way beyond the CC and BB stuff). My first 2-channel system consisted of a Cambridge Audio 640C CD player, HK PA2000 amp, Parasound PHP-850 pre and a pair of Polk Lsi7's (new) -- all for approx. $1,000.
    If I had to do it again, I'd get the best used integrated amp I could find.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2005
  • steveinaz
    edited March 2005
    Danny-
    How do you like your C-3's? I've read alot of glowing reviews on those, and have pretty much decided that if I ever go bookshelf again, it'll be the C-3's or ACI Emeralds....
  • Danny Tse
    edited March 2005
    Steve-
    I actually started with a pair of Energy C-1's, which are excellent in my small den. However, while browsing at my local dealer, I came across a sale on the C-3 for $300.00/pair (MSRP $500.00/pair) and I decided it was too good of a deal to pass up. The Connoisseur series use an aluminum tweeter that's quite detailed, but not bright at all. Not even when "out of the box", but they do sound better after breaking-in. They don't go especially deep in the bass, relatively to something like the NHT SB3, but what it can do is tight and fast. Excellent in the midrange frequencies....which to me, is more important. These speakers are front-ported and that makes positioning them easier than with rear-ported speakers. In the $400.00/pair range, the Monitor Audio Bronze B2 is just as good. Beware that the C-3 does dip into 4 ohms at certain frequencies, based upon the lab test done by soundstage.com. Here's the link to the review....
    http://www.soundstage.com/revequip/energy_c3.htm
    It's not everyday that I can afford a speaker that gets mentioned in the same sentence as Revel speakers.
    Energy is also readying a new Connoisseur Reference line....more expensive than the regular Connoisseur line but cheaper than the Veritas line.
  • shack
    shack Posts: 11,154
    edited March 2005
    The rig I've got set up right now for some Cable Swap demos is pretty nice an meets the $1,000 threshold. All gear was purchased used and is 8/10 or 9/10 with actual purchase prices listed (including shipping)....
    NAD C160 stereo pre-amp $325
    NAD C270 stereo amp - $320
    Cambridge Audio D500SE CDP- $215
    AQ Sidewinders - (Part of price with CDP)
    Polk RT400 Speakers -$85 (or RT25is purchased new for $85)
    Signal Cable speaker cables - $50 (actually free but gotta put a price.)
    A real world system comprised of well regarded gear for $995.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited March 2005
    I'm over the $1,000 limit, but not by much:
    SDA SRS 2: $230
    Dodd Pre: $300
    Sunfire Symphonic Reference amp: $600
    Toshiba CDP: $50
    Blue Jeans ICs: $20
    Total: $1200
  • madmax
    madmax Posts: 12,434
    edited March 2005
    I'm working on mine now.
    DecWare HDT speakers (home built)
    Drivers: $295
    Cabinent materials: $125
    Toshiba 3960
    Unit: $48
    Modification parts: $125
    Sonic Impact 10W T-Amp
    Unit: $22
    Modification parts: $150
    Cables
    Audioquest Type IV wire: $40
    Home made interconnects: $50
    Home made power cable: $60
    Total cost: $915
    Should equal the sound of a $6K system. :D
    madmax
    Vinyl, the final frontier...
  • TroyD
    TroyD Posts: 13,124
    edited March 2005
  • George Grand
    George Grand Posts: 12,258
    edited March 2005
    How about this from a few years ago:
    Marantz "Esotec" SC-8 preamp, mint in original box - $5.50
    Marantz "Esotec" SM-8, 100wpc pwr amp, mint in original box - $5.50
    Nakamichi 581 cassette deck - mint in original box - $10
    KEF Reference 102A speakers - $26
    For the mathematically challenged, it's under $50 for the package. Everybody can just quit now.
    I can put together about 5 or 10 more systems like that, which I have nailed over the years.
    George Grand (of the Jersey Grands)
  • George Grand
    edited March 2005
    Now if it's REALLY low dollars you want to hear about, this was purchased AS A SYSTEM, less than a year ago:
    NAD 7130 receiver
    Yamaha auto reverse cassette deck
    Yamaha single cd player
    Bang & Olufsen turntable
    Every piece works like a charm, is still under this roof, and cost me the princely sum of 2 U.S. dollars TOTAL.
  • Jstas
    Jstas Posts: 14,973
    edited March 2005
    Onkyo P-301 Preamp -- $100
    Onkyo T-4210 Tuner -- $50
    dBx DX3 CD Player -- $0.00 + $2.50 in parts to repair
    Adcom GFA-535 MKII -- $140
    Polk Audio SDA 2B -- $350
    Total $642.50
    Not too bad especially since the Onkyo stuff is less than 4 years old. It's all standing right next to me right now.
    Expert Moron Extraordinaire
  • George Grand
    edited March 2005
    You spent more for parts to fix the DBX cd player that I gave you than I spent for the entire above system.
  • pjdami
    pjdami Posts: 1,894
    edited March 2005
    It is surprising what one can put together for $1,000. One of my two channel rigs fits that category. All used equipment here....trying to remember....I believe it ran me $1,150 but the extra $150 was well worth it. If one is patient and lucky then the following can be had for about $1,000.
    Rotel RCD-961 cdp
    Melos SHA-1 tube linestage preamp
    B&K or Parasound amp
    Polk Monitor 10As w/ Peerless tweets
    Sounds wonderful and holds its own against my more expensive rigs.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited March 2005
    Perhaps the quotation marks should be one word to the right in the thread title? ;)
    What is the definition of a reference system? I'm serious. Personally, I don't use the term but I've seen it used frequently. I've always assumed (another tricky word) it meant a benchmark system - one by which all others are judged, compared, or evaluated.
  • George Grand
    edited March 2005
    Excellent point. I would now submit that the system I purchased above for $2, is THE BENCHMARK for all systems containing a receiver, turntable, cd player, and cassette deck selling in the $1-$10 range.
    The same statement would apply to the sysytem I accumulated for under $50 in the post above it. For giggles I will add the Euphonic Technology ET-650 cd player I purchased for $5, bringing the sum total of a system to $51. I believe it sets the standard for systems containing speakers, separate amp/preamp, cassette deck, and cd player for under $52.
    VR3 Posts: 29,392
    edited March 2005
    A reference system is something you compare everything else to...
    Kind of like a 'reference material' - which you use to demo gear with, etc
    Thats my take
  • George Grand
    edited March 2005
    I want to adopt a word. Are there any that look like Jenny McCarthy?
  • madmax
    edited March 2005
    Originally posted by George Grand
    Jenny McCarthy
    Georges reference woman...
  • George Grand
    edited March 2005
    ABSOLUTELY! The one to compare all others against! MAX, that was beautiful!
    George
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited March 2005
    At this point:
    Maggie MMG-$550
    Anonymouse/Madmax 3960 -$200
    Gruntball Carver: $200
    Passive Pre -$85
    $1035 without cables.
    George: Still working on the other project, just dealing with a family issue on that end.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • George Grand
    edited March 2005
    Jenny, Jenny.....Jenny.
    Thanks mon!
    George
