HDTV listings guide..?
gshisme
Just got my HD hooked back up through our local cable company RCN. Just wondering if there is an online HD channel guide to use. I have tried TitanTV and they list all the channels from my RCN cable provider except the HD channels. WTF.
I'd like to find an online guide where I can set up just my "favorites" (all the HD channels) so I can find out what's worth watching at a glance.
Help!
Greg
Help!
Greg
suds, suds and more suds!
Post edited by gshisme on
I just use tvguide.com. You can select your service provider and choose to view HDVT listings only...
At titantv, you have to manually add the hd channel using the channel number and callletters because those numbers vary in each market for cable companies. Once you et it up, it will remember them and you can add those channels to your favorites tab there.
Cool, thanks guys.
I also checked out HDTVGALAXY...not bad but it doesn't show the HD programs for morning and early afternoon. Specifically HBO, SHOWTIME and Cinemax.suds, suds and more suds! -
fireshoes,
Cool, got 'er all figured out. Pretty neat seeing all those little red HD letters everywhere in the listings.
Polk, I'll check out the tvguide sight a little later.suds, suds and more suds!
