Titanic SE in October
Ron-P
http://www.thedigitalbits.com/#mytwocents
A 2-disk and 4-disk will be available, finally. No word on a dts track or not but one can only hope. At least we'll finally get an anamorphic picture.
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
so the one out now isn't widescreen?
It's a non-anamorphic widescreen.If...
Ron loves a film = don't even rent. -
what's the difference? Is anamorphic the WS that still has the black bar on top and bottom?
Here ya go bro...a copy paste from the HTF.
What are "anamorphic" DVDs?
Many widescreen DVDs feature what's called "anamorphic" enhancement. You can't always tell by looking at the DVD cover, because the studios don't have a standard format for listing this feature. Often it's referred to as "enhanced for 16:9". Sometimes you'll see "enhanced for widescreen TVs". And often there's no mention of it at all (e.g., most DVDs from Columbia Tristar).
The following explanation of anamorphic DVD is one from the vaults. It was written by former HTF admin Rob Gillespie, and it's the best short explanation of the subject I've ever seen.
Rob's explanation talks about "scan lines". "Scan lines" are what make up the picture on your TV screen. Your TV draws 480 visible scan lines across the screen 30 times every second to "paint" the video picture you see. When films are presented in widescreen, some of those lines have to be used to draw the black bars, which is something of a waste. DVDs offer a way to make better use of those scan lines, and that's what anamorphic enhancement is all about :An anamorphically enhanced DVD spreads the image over more scan lines, increasing the resolution. Where do these extra lines come from? Well, on a normal letterboxed transfer, they are the space used for the black matting bars. If you play such a transfer on a standard 4:3 TV, the image appears tall and thin.
OK so far?
When an anamorphic DVD is played back, obviously the image needs to be restored to it's correct proportions. There are three ways this can be done.
On a standard 4:3 TV, the 'squeeze trick' can be done. This consists of entering the service mode and reducing the vertical size of the viewable picture until the proportions are correct. You're basically doing the same adjustment that's possible on computer monitors. On most European and very few American TVs, there is a proper '16:9' mode which does the squeeze trick at the touch of a button.
On a 4:3 TV without doing the 'squeeze', the DVD player must be set to '4:3' within it's setup menu. This forces the player to 'downconvert' the anamorphic image by removing some of the scan lines. This plays the image back at the correct proportion, but obviously loses some of the original resolution. It can also introduce unwanted artifacts, especially on scrolling credits etc.
On a widescreen TV, if the correct screen mode is used, the anamorphic image is stretched laterally, restoring it to the correct proportions.
Right.
The aspect ratio of the film itself is completely independent to the above. On an anamorphic DVD, the AR can be anything above 1.78:1.
OK?
A normal 'widescreen' DVD presents the film in it's proper aspect ratio (eg. 1.85:1, 2.35:1 etc) but does not include the anamorphic enhancement. This means the image is spread over fewer scan lines, dropping the resolution somewhat. This will play back fine on a normal TV without adjustment, but will obviously have the 'black bars' top and bottom depending on the AR. If played on a widescreen TV, the set must be put into the correct picture mode (on Sony's, it's usually 'Zoom', but varies with other makes).If...
What a dumb movie...
Well I thought Kate Winslet was hot....and she got nekked!
