Line Conditioners: Friend or Foe?
heiney9
Ive about had it with the strange noises coming from my speakers. I have terrible AC coming out of my wall sockets. I also seem to have a lot of stray RF noise coming through my system. Not sure where these noises originate from. Ive heard glowing stories about line conditioners increasing clarity, definition and lowering the noise floor. Ive also heard stories about it ruing the soundstage and choking the system so it sounds hollow, thin and lifeless.
So what are peoples experiences and opinions? The 3 Im most interested in are Adcom, Panamax, and Monster. But please discuss all types and brands.
Heiney9
Heiney9
Post edited by heiney9 on
At least from an engineering stand point, conditioners are a wonderful thing.
As for listening, I won't comment since I haven't done A/B comparisons with conditioners vs. no conditioner.Brian Knauss
ex-Electrical Engineer for Polk -
I like the "effects" of the conditioner on all of my components EXCEPT the power amplifier. Conditioner's have a habit of reducing the "slam" factor of your amp, for whatever reason--I don't know. But I did experience this first hand. Now my amp is plugged directly to the wall, and the slam is back. My CDP, Tuner, Preamp, and DVD are plugged into the conditioner.
At any rate, I don't know how effective a conditioner would be if you have genuine ac line problems; buzzing, hum, etc....
Some day, if you're bored to death; pull your wall plate check the connections, then go out to your electrical box, turn off the mains, and tighten all your connections. The setscrews can and do work loose sometimes, introducing noise into your ac.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
You may want to check out the PS Audio UPC-200. It's totally passive, high current and can be set up with 2 zones which is great for keeping the power and source separate. In my case, I've experienced no negative effects and the slam actually increased.Political Correctness'.........defined
President of Club Polk -
I also have the UPC-200 and noticed a marked reduction in noise floor with tube audio gear.
An alternative which you may also find interesting, the Transcendent Balanced Power Supply, can be found here. -
They can limit the amount of current available to your power amp... so avoid using it there until your at a last resort, then make sure the wattage/ amperage rating on the conditioner is way above what your amp pulls.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Belkin has some good stuff out too. If you're interested in any of THESE let me know and I'll getcha a price.comment comment comment comment. bitchy.
Thanks for all the replies so far. Im not really sure if my problems are really from the AC line or if they are more related to RF interference. Im at work now so I cant really go into detail right now. When I get home tonight Im going to listen to all my noise and then Ill describe in better detail what I hear.
I suspect that if I did get a line conditioner I would hear a difference pos. or neg., but it may not solve my noise problems.
Heiney9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Definitely look at your connections in the breaker box, especially grounds. It's not at all uncommon to find a few loose ones.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I have a problem with too little current reaching my amplifier. When at even moderate volumes, it will significantly dim the lights at bass peaks. Do they make a power conditioner type device that can solve this (similar to a stiffening capacitor in car audio)? I realize it would be a much more complex device for an alternating current source, but my amp pulls 1350 watts, and i live in an apartment where i can't install a dedicated circuit.HT: Yamaha HTR-5660, Front-RTi38, Center-CSi40, Rear-RT15i, Rear Center-RT15i, Subs-2x Polk DX12 in custom enclosures, Sub Amp-Harman/Kardon Citation Sixteen
PC: H/K AVR 65, some DIY bookshelves
The truck: Pioneer premier head, MTX amps, XM radio, 2 pair 6.5" DX Components, 1 DB 12" sub (the old one) -
heiney9,
Whats your budget for conditioning?Originally posted by stam4p5
FYI (in no particular order):
Exactpower
MonsterPower
AudioPhile APS
PS Audio
Furman
I have looked at all but the Exactpower unit and the specific Furman unit in the link.
There is also another at a more affordable price made by ?? When I think of the name, I will post. -
Sorry, you're SOL... What you can do is go in the breaker box and figure out which breakers control which outlets/ lights, then try to plug the amp into a circuit that has the least & plug the rest into other outlets. I don't think even a power regenerator would fix your problem.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Check out the Tripplite LCR2400. What it does is selects the proper coils of an internal transformer automaticly to keep the output voltage constant. (brownout protection). On a particular circuit I have which also has my chandelier on it the lights tend to flash quite a bit which means there is a fairly big voltage drop. With the LCR2400 in place the lights get much worse but the output voltage to the amplifier stays constant.
madmax
Edit: Here is a link.
http://www.tripplite.com/products/product.cfm?productID=2832&print=yes
You can find them for around $300 from internet stores.Vinyl, the final frontier...
Yes, the other unit I was thinking of was the Tripplite unit. Thanks Madmax.
unc2701,
The units listed in my post regulate power. They ARE used to correct the problem stam4p5 is having. He is not SOL. There is a solution.
From the Exactpower site:
If the AC at your wall socket is... (corresponds to the same line number below)
120 volts
115 volts
110 volts
105 volts
100 volts
95 volts
The EP15A can produce...
1,650 watts
1,550 watts
1,500 watts
1,450 watts
1,400 watts
1,300 watts
In addition, the
- Exactpower unit also filters/corrects the existing waveform to remove line noise.
- PS Audio and AudioPhile regenerate the power to output a pure waveform and regulate the power. The PS Audio unit has many additional features as well. -
Good point- the problem isn't the lights dimming, it's the brown out to the amp
I was thinking of the whole circuit. The lights will still dim since the every bit as much current will be pulled through, but you're totally right- those will keep the voltage up for the amp.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Thanks for all the suggestions. Should I be concerned with the voltage drop to the other equipment on the same line? My multimeter jumps from 120.6v (no load) to 92v (bass peaks). I am a little conerned about damage to the other electronics until I find the conditioner i want.HT: Yamaha HTR-5660, Front-RTi38, Center-CSi40, Rear-RT15i, Rear Center-RT15i, Subs-2x Polk DX12 in custom enclosures, Sub Amp-Harman/Kardon Citation Sixteen
I use Belkin got mine 50% off clearance at Home depot. Does the trick, yet I never noticed any problems. I use it more for surge prtection, it does have a filter , does it work I can't tell you !!
cost 25$ CAD -
...Check out the Tripplite LCR2400. What it does is selects the proper coils of an internal transformer automaticly to keep the output voltage constant. (brownout protection). On a particular circuit I have which also has my chandelier on it the lights tend to flash quite a bit which means there is a fairly big voltage drop. With the LCR2400 in place the lights get much worse but the output voltage to the amplifier stays constant.
madmax...
For what it's worth, I use a Tripplite. It has a continuous output of 1800 watts. My 2-channel amp has a max draw of 1600 watts so I assume I won't negatively effect my amp so long as nothing else is connected. But this didn't even dawn on me before. I believe I have several other pieces connected to it too since it has surge protection, line conditioning, etc.
I'd hate to not have my amp on quality surge protection so maybe I'll remove all other components from the Tripplite and hook them up to some other surge protector.
That way I'll feel comfortable that I'm supplying adequate amounts of juice to my power-amp and hopefully all my smaller components will be getting what they need to, just not a conditioned line.
I haven't tested the effects on sound with the conditioner to my Lsi15's, but I probably will now
What you bought at Home Depot is just a surge protector, not a HT type of power center that I linked to.Originally posted by Willow
cost 25$ CADcomment comment comment comment. bitchy. -
I'll chime in with a vote for the Tripp Lite LCR-2400. I have all my power amps plugged into it, and it in turn is plugged into a 20 amp circuit. I have very dirty AC in the apt. I am in, and the LCR-2400 has worked the best, with very little loss of "slam" effect on the power amplifiers.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Wow. 120.6VAC, while within +/-5%, seems awfully low to me. I would be tempted to go ahead and file a voltage complaint with your local utility. It could be that your transformer is loaded up to the point where your voltage is barely within specs, but once you add some rather dynamic load, the voltage drops like a rock, not to mention that your service cables could be undersized as well. Are these older apartments that were built before A/C was added? Do you have a window shaker?
Just some thoughts...
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
No, the apatment complex is less than 2 years old. They have doubled the size in the past 8 months, however, and i don't remember anyone upgrading the equipment.HT: Yamaha HTR-5660, Front-RTi38, Center-CSi40, Rear-RT15i, Rear Center-RT15i, Subs-2x Polk DX12 in custom enclosures, Sub Amp-Harman/Kardon Citation Sixteen
