Yamaha CR-640... I want to open it and clean it!
boltaction
Yamaha CR-640 Amp seems to be fuzzy and when I turn the volume up I get crackling in the left side. Not only that but the woofers slowly rise and fall when you raise the volume fast. I want to open it, replace all the little lamps inside (they have since burned out) and generally clean the entire interior. What should I do, what shouldn't I do, and what should I look for when cleaning out my reciever?
Post edited by boltaction on
Get some contact cleaner from Rat Shack, it comes in a spray can. I used some on a friend's CR 1040 receiver. The pots were noisy and that did the trick.
Check here for vintage parts. I got lamps for my Marantz 2226 receiver there. -
what is a pot?
"pot" is short for "potentiometer" and is the device the knob is connected to that controls the volume.HT: Yamaha HTR-5660, Front-RTi38, Center-CSi40, Rear-RT15i, Rear Center-RT15i, Subs-2x Polk DX12 in custom enclosures, Sub Amp-Harman/Kardon Citation Sixteen
PC: H/K AVR 65, some DIY bookshelves
The truck: Pioneer premier head, MTX amps, XM radio, 2 pair 6.5" DX Components, 1 DB 12" sub (the old one) -
Thank you for pointing that out. What else do I need to clean? Like the RCA female plugs, whats a good way to do that? How about other circuitry?
