I need some head...
spackelman
I need some head unit advise.
Newbie here. Please don't laugh at me.
Not that much of a audiophile. Just want clean, crisp highs and some good bass.
Have a chevy 2002 crew cab. All stock sound, with a 1.5 din opening.
Want to install a new system. I prefer no amp and no subwoofer.
Head Unit I like is the pioneer premire 960 or pioneer 9600 or kenwood x979. I like the fold out panel.
Speakers front - polk components. speakers rear ??
I've been told to go with mb quart speakers. I like polks
Total system cost would like it to be kept under $900.
Would like to have a gm direct fit hu, but the choices are too limited.
I've seen a pic of one gm install - It showed 1.0 din hu, with a 0.5 din equalizer under the hu. Looked kinda cool and filled up the space.
I need all the advise I can get. Thanks in advance!
Post edited by spackelman on
youre willing to spend $900 but dont want an amp??
thats kinda odd...
any speakers that are going to be expensive ($100+) need to be amped...
i can understand not wanting a sub but not wanting to amp speakers when youre willing to spend that much is kinda weird.
the head unit with the equalizer under it was most likely custom.
the premier 960 is a great head unit. look at electronicscity.com
theyre the cheapest authorized dealers of pioneer i have found.
polk will do very well for your requirements. since you don't want an amp, you'll want the db series.
i am partial to the premier line of pioneer's head units, but between those two, it's personal preference and features. the advantage here of the pioneer is that the equalizer is much more extensive, and automatic (i'm not sure that the kenwood's is). but, why go with top of the line if you're not an audiophile? for what you seem to want, nearly any pioneer, kenwood, or alpine would fit the bill at a much lower cost. there are also gm fit HU's out there; you did mention them, but take a second look, for what you want, they're no worse than the top end stuff.
the extra space could be filled by the mounting kit, or an external equaliser, depending upon the HU's capabilities.
but yeah, why no amp?It's not good, very fundamentally simply not good. - geolemon
OK OK - I need an amp. Which one?? Keep it small (the physical size of the unit).
The reason I like those hu's is for the the fold down control panel. It covers the 1.5 din space and simple looks cool.
I figured if I was going to sacrifice the amp, I should go with a top of the line hu.
I have only found (4) - 1.5 din hu. 2 by pioneer, 1 by jensen and 1 by pyle. Are there any others? They all seem a little out dated.
I do however like the look with the equalizer. Metra seems to make an install kit with an equalizer option or a storage pocket under the hu. This will work
Thank you for support feedback so far.
By the time I'm done, you guys will teach me a lot. Thanks -
You can get an adapter plate that will fit your GM and fill in the entire area and look OEM.
For an amp in this application normally we would recommend a Profile or other budget amp but Sounddomain.com has MTX Thunder amps on clearance right now and you can get this awesome Thunder282 for $110 which you wont be able to beat anywhere else.
For speakers, I say stick to fronts only. Better imaging and overall sound quality. MB Quart are great speakers but for the money you cant beat Polk Audio. And for speakers Id say go with these DB6750's for $200. However for a little more you could get these MMC6500's which will hold their own against most speakers on the market for $255.
For a head unit, it doesnt matter too much. Get a good Pioneer, Alpine, Sony or Kenwood and youll be fine. Look for 4 volt or higher preouts. Also look for a subwoofer preout in case you ever want to upgrade.polkaudio sound quality competitor since 2005
Thanks for the advice.
looked at the amp, sounds like a plan. Like the fact it is made in usa.
If a get a top of the line hu and if I put a small equalizer under it, will this help the hu or hinder the hu, espescially if I add the amp.
I do have rear door speakers. I do what to change them. What polk's can I use.
Can I add simple mid range speaker and not screw up any performance of the "system" -
amp, good choice. if you get a TOTL HU, you won't need an external EQ, the included EQ will be much better (in pioneer's case, not necessarily kenwood's).
adding only the midrange to the rear is actually an excellent idea. if you choose the mm6 or (maybe, i'm not sure, someone confirm/deny) the mmc6500, the tweeters are very powerful, and an extra midrange will help a lot without muddying the detail too much. good idea! (IMHO) only problem is getting the midranges alone, polk charges a pretty penny for extras.It's not good, very fundamentally simply not good. - geolemon
I do understand the equalizer is not needed.
I am only trying to fill up the space with the 1.5 din space.
A nice little unit, nice lites, more adjustments, just looks a little better - totally just for looks.
My main question, will this added equalizer screw up my TOTL hu.
Again, thanks for the input. I am learning. -
You wont need to fill up that space. The installation kit you get for the head unit will take up the entire opening.
An EQ wont necessarily mess up your h/u's performance but you simply dont need it.
If you want rear speakers, just get a set of DB coaxials. Its not a bad thing to have rear speakers just not the optimum thing. If you haul around passengers and listen to music a lot then you may want rears.
Of course then youd be better off getting a 4 channel amp.polkaudio sound quality competitor since 2005
2002 Chevy Silverado 2500HD - Crew Cab
I ordered my stuff, this is the system:
Head unit: Pioneer DEH-960MP (Electronics City.com ($399.00)
Amp MTX Road Thunder RT404 (Car Domain.com $164.95)
Fr Speakers Polk MMC 6500 Componets (Car Domain $299.00)
Rr Speakers Polk db 675 (Car Domain $109.95)
Will this work??
I hope it all comes together as planned. -
ignore that one, it's a doubleIt's not good, very fundamentally simply not good. - geolemon
