SDA's in a 5ch setup?
jrausch
jrausch Posts: 510
edited August 2001 in Technical/Setup
Has anyone here used SDA's w/cable's connected in a surround setup. Does this work with the correct L+R, R+L phasing? I am thinking of setting up some SDA 1's in the front and some CRS+'s for the rear. also, I have a 65" widescreen setup and was contemplating on a Polk center. I want the entire screen covered as far as center imaging is concerned. I will be using my Denon 5700 for power.
Feedback is much appreciated,
Thanks, JR
"The only way to get rid of a temptation is to yield to it."
Post edited by jrausch on
  • BobMcG
    BobMcG Posts: 1,585
    edited August 2001
    ...there are quite a few all SDA theaters out here, and that means w/cables.
  • crystal-clear
    crystal-clear Posts: 19
    edited August 2001
    I have Sda Srs 2.3tl's as my front mains in my 5.1 ch. setup. It sounds great to me, and I am a picky person! I have f/x500i rear surrounds, psw650 sub, and a cs400i. All with plenty of power. This setup works for me, if you have any questions, let me know, I'll try to help you out.
    Later cuz,
    Crystal-clear:) :)
  • axeman
    axeman Posts: 170
    edited August 2001
    My 1.2 TL's are the main component in my surround setup and lemme tell ya...................ain't nuttin better........................Rock On!
    Joe;)
