Onkyo 601 Zone 2 Line out
edited March 2005 in Electronics
I am kind of confused with the manual, if I hook up a power amp to the line outs of the Zone 2, would I have volume control? It says it is a fixed output.
Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72
Post edited by masanz1 on
    edited March 2005
    If it says it's fixed, then it's probably a 200 mv fixed output- Like a rec out. basically it'll be the same volume as if you hooked a DVD lpayer straight to your power amp. So you can either get a preamp or if your power amp has a 1v sensitivity, that'll be plenty for most the time so you can just use a line level/ speaker level volume control. You'll just lose roughly the top 6db of the amp's power... but you'll never have to worry about frying your speakers.
    Backburner:Krell KAV-300i
Welcome!
Welcome!
