New Polk'er: Need your advice
thegoldenhand
thegoldenhand Posts: 8
edited March 2005 in Speakers
Hello! I'm a new owner of the Polk R30s. My problem is I am having a difficult time finding a store that still sells the CSi20 center speaker. I need suggestions on what I should do to for my center speaker?
Is the CSi20 the only one that will match well with my R30s ever?? Will the CS1 blend well as well? What settings should I consider or pay attention to when I get t he CS1? I use a Panasonic XR50 digital amp. I also use the Dayton Audio TM2 for my sub. Any other Polk centers to consider? SHould I go with a different brand for the center?
Post edited by thegoldenhand on
    F1nut Posts: 51,763
    edited March 2005
    Have you looked on eBay?
  • thegoldenhand
    edited March 2005
    Yes' I just looked on ebay. I found 1 but lost on the bidding as I ran out of time to outbid the high bidder. I was in it till the last second but unfortunately I wasn't able to get my last high bid in. Got any ideas where else to find a CSi20?
    F1nut Posts: 51,763
    edited March 2005
    Nope, sorry. Keep looking on ePay, I'm sure more will surface.
  • danger boy
    danger boy Posts: 15,722
    edited March 2005
    several other Polk centers will closely match your R30's for the tweeter. the CSi20 isn't the only one. just depends on how much you want to spend for a center.
    Even the current line of centers will match well with your R30's.
    CS1, CSi3
    if i were you. i'd stick wth the center from Polk. I tried in the beginning to go the el cheapo brand route for a center. and it never sounded very good.
    PolkFest 2012, who's going>?
  • danger boy
    edited March 2005
    CSi30 on ebay
    here is one CSi30 listed on ebay that will match your R30's
  • danger boy
    edited March 2005
    CSi40 on Ebay
    this one is a big beefier than the CSi30. this one will also match your R30's
  • kevinfc
    kevinfc Posts: 16
    edited March 2005
    Hey,
    Try this site. http://www.ayselectronics.com. They sell the entire R series line.
    You're about as useful as a poopie-flavored lollipop
  • miner
    miner Posts: 1,305
    edited March 2005
    Look on AudioGon - www.audiogon.com - quality used equipment; mid-fi to hi-fi.
  • thegoldenhand
    edited March 2005
    thanks for your responses guys!!!
