Polk RT400
I just picked up a pair of these speakers. I cannot find too much info on this sight about them. Are they kind of rare? Will they match up OK with my RT600i? Also the rubber seal inside the speaker grill mounting hole is missing, where can I get replacements. Thanks
Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
SVS 20-39PCi
Infocus IN72
Post edited by masanz1 on
They're discontinued. http://www.polkaudio.com/home/products.php?category=3&speaker=255&vintage=1 They look very cute. They won't match your 600i tonally because of the different tweeter and woofer. If you plan to use them as surrounds, go for it. IMO, matching mains with surrounds is not very important unless you're very picky or is a perfectionist.
You could contact Polk and ask them if you can order some of that rubber seal for the grills. E-mail them, I'm sure they can do something for you.
btw, congrats on the find. Not too many people own the RT400.
Maurice
