Amp Kits
bam88
bam88 Posts: 82
edited March 2005 in Car Audio & Electronics
Streetwire or Stinger? something else?
Post edited by bam88 on
  • bam88
    bam88 Posts: 82
    edited March 2005
    Do I need a separate power chord for both? (MTX1501D)
    I Plan to run them to batcap(s) Just didnt know if i could connect them in a sequence or they had to be separate. Any Ideas?
  • exalted512
    exalted512 Posts: 10,735
    edited March 2005
    knukonceptz.com
    do you just have 1 amp?
    -Cody
  • bam88
    bam88 Posts: 82
    edited March 2005
    x2 1501D MTX amps
  • bam88
    bam88 Posts: 82
    edited March 2005
    but if you had to choose streetwire or stinger which would it be?
  • exalted512
    edited March 2005
    I like street wires RCAs better...but I don't know why you would chose one of those since knukonceptz is almost twice as cheap, comes in a variety of colors, more flexible, tinned, and has a better jacket...
    -Cody
  • Jstas
    Jstas Posts: 14,842
    edited March 2005
    Streetwires
    Expert Moron Extraordinaire
  • bam88
    bam88 Posts: 82
    edited March 2005
    Well I can get a real nice 0ga streetwires kit with RCA all highend stuff for like 60bux
    So is it two separate powerwires? or can i chain them?
  • bam88
    bam88 Posts: 82
    edited March 2005
    checkem out
    Tell me what ya think :cool:
  • exalted512
    edited March 2005
    just send them to a distro block
    id still go wth knukonceptz. that kit when its shipped it $70...
    you can get knu for just over that b/c youll need a distroblock as well. and the knu is a better kit(youll also have to get their rca's which are pretty damn good so ive heard, id venture to say better than the musicas and im a big fan of SW interconnects
    -Cody
  • bam88
    bam88 Posts: 82
    edited March 2005
    both amps are 0ga amps is there such a thing as a 0g input with two 0ga outputs? if youve seen it ... please point me in the right direction.
  • exalted512
    edited March 2005
    you can do 0awg input to 4 awg outputs without a problem
    -Cody
  • bam88
    bam88 Posts: 82
    edited March 2005
    chit silly me here im thinking if the amp says 0ga it wont work with anything else :D whoa ... have i got a lot to learn .... see what i plan on doing is just getting it all together for the best prices i can find and taking it to a pro and say how much to put all this in. well... thats my plan anyway.:)
  • bam88
    bam88 Posts: 82
    edited March 2005
    I wont loose any power using the 4ga from the distro? Sorry.. I just want it to be perfect the first time i do it.
  • exalted512
    edited March 2005
    installing amps isnt that hard...its extremely simple and straight forward...id seriously consider doing it yourself...
    as long as its a short run of 4awg, like 2 ft or less you will not have a problem
    -Cody
  • bam88
    bam88 Posts: 82
    edited March 2005
    Jus one amp would be kewl but ... the other amp wont exactly fit across the back wall the anchors for the seatbelts will be in the way. Plus gotta have the box fabricated that is whats gonna kill me price wise.
  • bam88
    bam88 Posts: 82
    edited March 2005
    the batcaps too.. i have no idea bout that stuff
  • exalted512
    edited March 2005
    well everything you have installed before you take it to the shop will give you that much more experience and will be that much easier on the wallet
    -Cody
  • exalted512
    edited March 2005
    dont expect the installers to have every heard about a batcap before...
    -Cody
  • exalted512
    edited March 2005
    id print this and bring it to them
    http://www.batcap.net/Installation.htm
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    I vote Streetwires too. I also agree with Cody that you should do it yourself.
    Dont trust what the installer will tell you about the cap. Ive had them try to talk me into buying one with a 200 watt amp!!! I say hook everything up first and if you have voltage problems then look to a cap or something. Unless youre running a 50 amp alternator or 10,000 watts you probably wont need one.
  • bam88
    bam88 Posts: 82
    edited March 2005
    Well I found a distributor/fuse block that will go from 0ga to 0ga>>> take a look
    What ya think? :cool:
  • MacLeod
    edited March 2005
    Tha would work just fine.
  • bam88
    bam88 Posts: 82
    edited March 2005
    ok.. next question....where would i need fuses if the distribution block has a but load in it. On each branch of the 0ga to the amps? do I need the customary fuse b4 it gets to the distribution/fuse? OR does the fuses in the dist. block take the place of all of them?
  • exalted512
    edited March 2005
    youll need to have one within 18" of the battery. just a regular in line fuse holder. this is to protect your truck from catching on fire so its pretty important...then the distroblock you showed will have a fuse for each individual amp
    -Cody
  • bam88
    bam88 Posts: 82
    edited March 2005
    KEWL!
    :cool:
