Tube info thread "lets hear it"
faster100
faster100 Posts: 6,124
edited March 2005 in 2 Channel Audio
Maybe we can make this a sticky,
I was thinking today how alot of us are getting into tubes and always asking questions, wondering what tubes are good/better/great/ bad and brands, models... and so on.. I think it would be great specially for the tube heads who know alot about tubes, and for the tube newbies who want to learn more about them..
maybe list current made tubes we like, vintage tubes we like.. followed by brand, model, details.. I know some of us like to keep this info top secret :D but lets all get together and start a thread with lots of info... I for one do plenty of research on the net, however you can't learn everything from the net alone but from people who are old enough to know about tubes or have been into tubes for some time...
tubes i have/tried are all 12ax7's
Raytheon vintage 5751's
groove tubes (mullard remake)12ax7
Sovtek 12ax7
GE 6x4 black plate,
GE 6202 black plate
Rca 6x4
Jan phillips 6x4
and unknown maker 6x4wa black plate... all sound similar to me so far, BUt my oldest 50's GE black plate sounds the best.
So lets see if anyone wants to participate in the thread...
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    edited March 2005
    anybody?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • nadams
    nadams Posts: 5,877
    edited March 2005
    You waited 2 hours and 17 minutes to bump something?
    Give the folks some time :)
    Ludicrous gibs!
  • faster100
    edited March 2005
    and? your point? It was no longer showing in new threads.... and so i bumped it to the top.... we all seem interested in tubes and most everyone on this board is on 24/7 :D I'm sure they have seen the post.....
    Thanks for the suggestion though :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • organ
    organ Posts: 4,969
    edited March 2005
    Sounds good to me. Here's a list of my favorites...
    EL34:
    1. Electro Harmonix EL34EH
    2. JJ E34L
    3. SED EL34
    It took so long for me to figure out which I like better but I guess the EH wins for its 'livelier' presentation. But the JJ's are very tube and warm sounding with good bass. AAAAAH screw it! Still a tie.
    Next EL34 I'm going to try: Mullard EL34 (re-issue by New Sensor)
    7199:
    1. RCA black plates
    2. JAN
    RCA is way better but the Sovtek can't even come close to the JAN.
    5AR4:
    1. Mullard
    2. Sovtek
    Mullard is much more powerful sounding with better bass and warmth.
    12AX7:
    1. Sovtek 12AX7LPS
    2. Ei 12AX7
    3. SED 12AX7
    12AU7:
    1. Mullard
    2. RFT
    3. Electro Harmonix
    6DJ8/6922:
    1. Mullard 6DJ8
    2. GE 6DJ8 (the one with black stuff sprayed in the interior of the glass to block RF)
    That's it for now.
    Maurice
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited March 2005
    Maurice, I've got some 6922/6DJ8 for you, if intersted, shoot me a msg. Amperex, RCA Mullard, Virgin Commies (OLD NOS Russians), etc etc.
    Cheers,
    Russ
  • organ
    organ Posts: 4,969
    edited March 2005
    Sent you a PM:)
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited March 2005
    Maurice,
    The RCA Mullard 6DJ8's are SPECTACULAR in my CDP - Thanks again, Russ.
    Mike
  • faster100
    edited March 2005
    so are these EI's i see on e-bay stateing being made on old telefunken machines good or a bunch of hooey? want 21 bucks a pair i think... calling them silver bullets...
    was gonna grab a set, before i tried vintage 12ax7's
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • BlueMDPicker
    edited March 2005
    Unless you need a ton of tubes, IMO save up, keep your eyes open, and get some NOS JAN/Sylvania or Mullards for all round satisfaction.
    There's a reason they cost more, and it isn't snob factor. I've run many 6CA7/EL34 power tubes with my DCM. Nothing comes close to Mullards for SQ. Same story with small signal tubes. I now have Mullards top to bottom in my push-pull rig. I'm done.
    Having said that, Ei does make some good tubes - especially if the amp/preamp was designed with them in mind. The Manley Stingray was purposely designed around their EL34 tube because it was current production. On the Ei small signal tube side, it's my understanding that there is really only one build with all manner of pin plating and buzzy branding going on. If you want to try them, get the cheapest ones you can find. Odds are it's the same tube inside, and that's where the rubber meets the road.
  • Early B.
    Early B. Posts: 7,900
    edited March 2005
    This may seem strange to many of you, but I've tried several 12AX7 tubes in my Jolida amp including Groove Tubes, Telefunken and Sovtek, and I keep going back to the EH. It doesn't necessarily do anything great, but it does everything well. The GT 12AX7M sounded slightly better, but every now and then I got static, so they had to go. The other tubes I'm using will stay right where they are -- Mullard 12AT7's and EH KT88's.
    "God grooves with tubes."
  • faster100
    edited March 2005
    I have the groove tubes 12ax7M's rolling in the pre now and like em alot.... My fav so far has been the sovtek 12ax7lps
    Paul has a new set of EH 12ax7's and likes em and wants me to pick up a set to try.... now that you mentioned likeing them also i may try em,
    anyone have any vintage 12ax7 tubes in the tele's or mullards? to sell...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited March 2005
    any one wanna add to the thread? Come on Russman i know you have tube lore in that head amongst other stuff to share in this thread :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
