New HT on a budget
My brother is finishing one of the rooms in his basement and is researching HT options. I think he's looking at the R30's in the front and the R15's in the rear. His room is relatively small, so he doesn't need anything extravagant to fill the space.
The speaker choice was also helped by the fact that the R30's in black are currently $50/piece, and the R15's in black are currently $50/pr on Outpost.com (and both are in stock...)
Now, we need to look at a center channel. I was thinking that another pair of R15's might do the trick. He's going to have a 72" projector screen at the front of the room, and maybe we could mount one above and one below?
I think that he's probably going to build his own sub... but we're not sure on that yet.
Any thoughts about the center channel? I've heard that Polk's recommendation of the CSi20 is less than stellar, but I could be wrong. Thanks,
nadams
nadams
Ludicrous gibs!
Post edited by nadams on
if it were me I'd buy another pair of R15's and use one (or both) as the center channel.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
R15's should sufice. Pretty economical and still offers good sound quality. Top and bottom all teh way. Buy/build a good subwoofer and it will be a good system. Other center channel options as i see it:
-buy one of the Radioshack 3 way loud speakers (tall rectangular, about $100). I have an old 3 way that is phenominal as a center. It has a horn with a brand name of "Realistic" that is clear and natural sounding. Exactly what I wanted. Plus I got mine as a hand me down from my best friend. I use 15's for fronts right now and the timbre is an ok match (incredibly).
-if your friend wouldn't mind spending some more dough, he could probably get a CSi3 on deal ($200-400, varies a hell of a lot). Good match for the R series, but that seems a little on the expensive side.
-look for centers used or open box returns. You can find good stuff."Nothing in this world is accomplished without passion."
-me
"Your buying what with your money? The money you should be saving"
-mom, on first learning of my purchase of a Harman Kardon AVR 235
"Jeter is playing golf right now. This is better."
-Manny Rameriz's poster for the World Champion Red Sox victory parade -
Crap, my bro just called outpost and the black R15's are actually $50 a piece... which is the same price as the R30's!
That kinda sucks...
I suppose it's still a decent price.Ludicrous gibs! -
So all R-30's???More later,
Tour...
Vox Copuli
Well, he's not sure now. He's considering just using existing speakers and using the money on something else. I personally am recommending the R30's.Ludicrous gibs!
