Di-pole or Bi-pole
beardog03
Okay guys quick question...
I just got my Fx`s..
They are on about 30"stands...1.5 ' from the side walls....and about 3' in front of listening position...
Di-pole or Bi-pole...
That is the question
got a movie called EPOCH evelution cued and ready to roll
it`s in Dolby Digital..
what do you suggest ?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
nope...to the side until I can mount them on the wall
If I look to the side of me they are about 10-12"ahead of being right in the line of sightCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
in my chair looking to the leftCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
ooops!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
thanks thug....Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
i'd go bi pole. but that's just me. bi pole if they are behind you. di pole if they are on the side of you.PolkFest 2012, who's going>?
thanks DB,
the movie sucked...
stayed in pro logic 2 inhanced..
wouldn`t go into DD...the sound sucked
Di=side
Bi=rear
that just sounds wrong !!
bi=rear ?
This is audio not sex....
if it was sex, bi=rear is way wrong....
let the comments commence...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
In your DVD player settings, make sure to turn DD or DTS on. (in some players)
Thug,
I had it turned to dvd-autoCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
bi or di. whichever sounds best to you. room acoustics will determine that. bi works for me. but my room is small and square. fiddle with both bi and di.
hmmm, move not in DD? that's kinda strange for a DVD today not to be in at least DD. I've never heard of that movie.PolkFest 2012, who's going>?
The speakers should be set to dipole if they are directly in line with your sitting position, otherwise bipole. With dipole, the drivers on each half of the cabinet are fired out of phase, which creates a null area straight out from the speakers position )which is how you want it). On bipole, they are firing in phase. There is no null spot, and it will cover a greater area.
thanks for the input fireshoes...
That makes sense to me ....
I want to put them on the back wall, but my couch and chair are about a foot in front of the wall..
is this still doable ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
