sub box??
halvard
halvard Posts: 16
edited March 2005 in Car Audio & Electronics
what should i use to my 2x mm2104 subs??
messurments on the box?? i have heard all from 40liters to 90liters??
please help?
Post edited by halvard on
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    Dont know liters my man but the MM2104 requires .66 cubic feet gross internal volume.
    As far as what to use to power it, youll want something puting out 300x2. I recommend a class D amp and it depends on how much you want to spend.
    In the money-no-object category,
    this Xtant 6.1 is the best out there.
    For a more budget choice this Phoenix Gold Xenon would work. So would this Sony.
    This Alpine would be my 2nd choice behind the Xtant and it goes for a good price.
  • halvard
    halvard Posts: 16
    edited March 2005
    i have the mtx thunder 421D amp to power the amps...
    1.38 cu. pr. chamber. i think is recommended.. i dont know.. very confused.. but.. is it better to make the box to big or to small??
  • halvard
    halvard Posts: 16
    edited March 2005
    thanx... yes i was thinking about a closed/sealed box for that tight bass...
    thanx for the info mate !!
  • exalted512
    exalted512 Posts: 10,735
    edited March 2005
    put some type of wire, something like chicken wire thats not too constructive on the inside of the port if you put poly fill in the box
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2005
    Originally posted by exalted512
    ...something like chicken wire thats not too constructive...
    -Cody
    constrictive :)
  • exalted512
    edited March 2005
    actually i meant obstructive, but yea
    -Cody
