Help!!!!!!!
boatlover 5254
I have a koss KS2503 system and when ever i try to play CDs or DVDs it says MSG 04 WAT I DO??
Post edited by boatlover 5254 on
Might be a dusty laser. Use a photo brush-bulb and clean it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
You might also want to bust out your user manuel and look up MSG4 in your troubleshooting section. You have the gift of error codes, use em'.
